Ray's motor is coming along
here's a few pics of ray's engine, crnak, piston, rods, cam, lifters, and Rivergate 5 speed back plate are all installed.
Hap Waldrop
Picture of the Rivergate 5 speed backplate, complete with thier rear seal kit.
Unlike the Mini Mania rear seal kit which eliminate the block rear scroll piece, this seal kit form Rivergate leave the factory scroll alone, and the seal is just in addition to the scroll. The MM kits never worked for long on the race cars, we gave up on them years ago, but I don't see how this could be a problem, since it retian the rear scroll, and the seal is nothing more than a back up.
Hap Waldrop
Rollmaster vernier timing gear set to dial in the APT VP276 slotdrive camshaft, also used APT's CF-04 chilled iron lifters.
Hap Waldrop
Well, time to call it a day, Ray spent most fo the day with me, we fit his tranny to the custom pilot bushing for the 210 5 speed, and then trial fit the tranny, so we knew he would not have any issues when this chore came along. I bolted the Goodson degree wheel and pointer on to the engine, so I'm ready to start degreeing the cam after the British Invasion of CMP.
Hap Waldrop
I will go over this, as most folks overlook this. Rod side clearence, turns out Ray's core had already been into, and the crank was .010/.010, and whoever turned the crank did a crappy job of it, greatly elminating most of the journal's radiuses, so I had a nice std./std core and we decided to use that. instead, we magnfluxed it then, striaght checked it, then taped the journal up and bead blasted it, then clean it again, then polished the journal, then balnced it. Since this was new cranksahft to assembl, there was no guarantee the rod side clearences were where we wnated them to be, sure enough #4 rod had hardly any side clearence, so it had to come back out of the block, and the rod side thrust surface were belkt sanded down until we got what we needed, we ended up being a range of .012-.014" on rod clearence, which is really good. Too little side clearence could lead too friction and heat building up there, which could cause a bearing failure, too much side clearence would let the oil blled off too quickly compromising oil pressure, .014 is considered optimum, so we're right where we need to be.
jlaird
Thank you Hap. Always learn something.
v8mgbal
That is one nice looking engine. can't wait to see it in his sprite project.
jlaird
Would not think a few thousands would but then what do I know? Hap?
Hap Waldrop
Glen_B said:
Doesn't sanding down a big end at this stage throw off the balancing?
Glen
Glenn you may want to search the thread "Rays rods" I balanced the rods, that why you see that machining on the cap of the big ends, I did that in a Bridgeport mill. The rods are all balanced ( big end, small end and total weight) to within a gram od ounce, the rod thread explains the entire rod reconditioning and balancing in great detail.
I think Glenn is asking if you had to make adjustments for clearance AFTER you balanced the rods and if so was the material removed significant to the balancing.
Hap Waldrop
Sorry, misunderstood the question. Balancing was the last operation, big end sizing was done before balancing, sometime you get a rod that that takes a recut of the parting line and extra honing which can easily reduce it weith a gram+, so I do balancing as the last act. The one rod I had to reclearence the side thrust area on was rechecked against the others, this time of course with the piston installed, the amount removed on the side thrust area was not enough to change the balancing +/- a gram. A gram sound like such a little amount of weight on a rod until you go to remove it, then you are astonished at how much material is really is.
mccalebr
A good day, and visit, it was!
Nothing like seeing the new engine to inspire me to get back into the garage and get some parts painted...gotta get some heat out there though or else the POR15 will not lay flat.
You just can't beat having a few hours to spend with someone who REALLY knows his stuff, and is a good guy to boot... wonderful day!
Ray
Hap Waldrop
Ray, next time you take a picture from that angle, give me a chance to put a hat on first :smile:
Hap Waldrop Ray's McCaleb's "The Spridget Project" motor build Spridgets 23
M Ray Juncal Valve Covers Austin Healey 5
T Hey Ray! My new hubs arrived also Triumph 8
RobT TR5/TR250 So Ray Magliozzi Owned a TR250! Who wodda thought Triumph 6
RickB Lookie what came today from Ray McCaleb!!! Spridgets 12
Hap Waldrop Ray's engine is done Spridgets 27
Hap Waldrop Ray's head Spridgets 1
Hap Waldrop Ray's bottom end Spridgets 5
Hap Waldrop Ray's oil pan Spridgets 20
Hap Waldrop Ray's engine, more goodies Spridgets 4
Hap Waldrop Ray's external oil system Spridgets 3
Hap Waldrop Ray's oiling system MG 5
Hap Waldrop Ray's rods MG 0
Hap Waldrop Ray's rods Spridgets 30
M Ray: I got the part today! Spridgets 1
tony barnhill What a Guy Ray [mccalebr] Is!! Spridgets 3
mccalebr Ray's Garage Spridgets 17
apbos Ray has been hiding something from us! Spridgets 1
mccalebr Hap's 1275 engine builds for Ray and Drew Spridgets 15
Hap Waldrop For Ray and Drew Spridgets 18
Bret Another X-Ray Image! Other Cars 15
Bret Classic Motorsports MAG; X-Ray Specs! MG 6
Bret Truck X-Ray! Other Cars 10
Bret MGB MGB X-Ray! MG 25
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
B Windscreen Motor Repair Restoration & Tools 6
HealeyPassion Pop Quiz: Displacement of 2912cc motor bored 30 thousands (0.030) over Austin Healey 3
W General Tech 2500S starter motor and fuse box questions Triumph 3
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
R TR2/3/3A TR3 Wiper motor Triumph 10
SNClocks Upgraded Motor Mounts Spridgets 4
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
M Engine Stand for 3000 Motor Austin Healey 7
E MGB MGB heater motor problem MG 3
edkap2002 TR6 starter motor advice Triumph 12
T Motor Jaguar 4.2 Jaguar 14
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Motor knocking at start up? Triumph 11
T TR2/3/3A wiper motor short Triumph 2
Darwin Spitfire Motor mounting help Triumph 1
3798j Off Topic My motor...it whistles... Triumph 2
60TR3A TR2/3/3A How Authoritative is the British Motor Industry Heritage Trust? Triumph 6
B TR4/4A Rubber wiper motor mounts Triumph 4
R Rewind electric motor Restoration & Tools 3
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
