radio antenna
radibob
So I have a working period motorola radio for my Sprite but no antenna and I am reluctant to drill any holes anywhere.
Anyone have a creative way to fashion an antenna on these cars without drilling any holes?
I have a trunk luggage rack and was actually considering insulating it from the body and using it as an antenna.
That might work pretty well.
I got a period fender mirror / Arial from the silent auction at Midget 50th and installed it.
Works ok, better than no antennae for sure, but not as good as a 'real' antennae. However, it's good enough to listen to the morning drive show on my way to work.
The OLD Fords mounted the antenna under the running board. Don't know why you can't mount below the body in rubber standoffs.
I also had one under the hood for a while - it worked but out from under the big metal bonnet is better.
You may want to look into boat antennas for this application. Not the big, old fiberglass ones, but the wire that you can tape to the inside of the dash or behind a panel. I've used them on several boats and they work really well...not the best, but good enough.
Rut
I bought some coil winding from radio shack and ran it along my roll bar. I connected that to the center lead of the caox coming from the radio. Then I grounded the shielding from the coax to the roll bar. It works way better than my conventional antenna did.
I am using a boat antenna on my BE. It is made by Shakesphere (they make lots of different boat antennas). It is a strip antenna that I installed just above the bottom of the windshield. It is very thin and goes about 1 1/2 feet at the bottom of the glass. I can send you a picture if you give me an email address. I like this antenna so much that I put one on my Pathfinder SUV. I did not want to drill a hole on the fender and this works great! Most people do not notice it until I bring it to their attention.
Charlie
Another good reason for a hidden antenna:
Nothing says "come steal my radio" like a big ol' aerial.
Go ahead, ask me how I know. :madder:
what about a copper strip stuck to the windscreen. RS sell CU tape, it's got an adhesive backing, and you can then solder the dialectric (inner core) of the coax to it. Insulate outer core this end.
The problem with most adhesives attached to the windshield is that the sun will break it down quickly. Then you are left with an ooze you need to clean up. Try to find something that uses the same adhesive that the DMV uses.
If you insulated it well I don't see why that wouldn't work, kellysguy. But how to insulate??? Maybe it would work anyway?
Kurt.
S Radio Antenna Spridgets 5
maxwedge5281 radio antenna location Austin Healey 17
S TR2/3/3A tr3 radio antenna hole Triumph 15
bcbennett Radio antenna lead Triumph 3
angelfj1 TR-3A Radio Antenna Options Restoration & Tools 4
2wrench Dropped radio antenna into fender. Triumph 21
G Fully retractable radio antenna Triumph 5
RSMTR8 Wedge TR8 Radio and Power Antenna Triumph 4
jjbunn Radio Antenna MG 12
G radio antenna replacement Triumph 7
zoohow radio and console mount Restoration & Tools 1
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
J TR2/3/3A TRIUMPH Radio? Triumph 13
D Removing Old Radio Austin Healey 4
T TR2/3/3A Question on old radio from my TR3 Triumph 9
Got_All_4 TR5/TR250 Pros and Cons to Wiring The Radio Direct Triumph 6
E Alpine radio for a US Model Db7 Volante Other British Classifieds 0
Hangtown Healey Barbie Clock-Radio Austin Healey 9
M General MG OEM Radio wiring help MG 4
pkmh Radio Knob Design For A 67 BJ8 Austin Healey 16
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
T how to have music/radio when driving Spridgets 33
7 Strange A/C - radio problem Other Cars 7
Jim McCauley TR6 TR6 Radio recommendation Triumph 4
M Fitting a modern radio Austin Healey 9
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
1 MGB '66 MGB radio measurements MG 3
6 Spridget Radio/Speaker Case Spridgets 4
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
Tim Tucker TR4/4A BENDIX Radio Model: 5SMTR manual? Triumph 2
T Wanted Wanted: BE Sprite Original Motorola Radio Spridgets Classified 8
F TR2/3/3A radio mounting plate Triumph 4
H Vintage Radio Austin Healey 9
Zitch TR4/4A Original Radio knobs Triumph 12
M S1 e type radio console Jaguar 2
wangdango BJ8 radio delete plate? Austin Healey 2
Got_All_4 TR2/3/3A TR3 radio console Triumph 30
Marvin Gruber Becker Mexico radio Austin Healey 7
kennypinkerton MGB Radio console removal question MG 4
D Radio! Other Cars 0
Zitch General TR WTB - Triumph AM radio. Triumph 11
roysimpsonjr TR4/4A Will an 8 inch wide radio fit? Triumph 3
Scotsman General TR Radio Triumph 4
M TR2/3/3A Phone charger & Radio can I put these in my car??? Triumph 7
K TR4/4A Stock Triumph Radio Troubleshooting? Triumph 4
G original radio 1961 e series jaguar Jaguar 3
TulsaFred Bugeye radio in-dash Spridgets 10
B orginal BMC radio Austin Healey 9
Mink TR4/4A Radio plate/dash support orientation Triumph 6
