radiator drain tap
carrottop
Anybody have problems with a replacement radiator drain tap from Moss? Just replaced an old leaky one and its washer and still have the same problem. Not leaking from the threads but the bottom of the tap. Moss is sending a replacement. They claimed no negative history with this part. Any tricks I should be aware of?
Thanks,
Eric (BT7)
I rebuilt my original and used some grease on the pivoting shaft to insure a good seal. I bound this out when replacing a hose bib that leaked. The stuff off the shelf sits too long and dries out. Then you turn it once and break the dry seal. Once fixed you need to turn it occasionally like once a year when you change the coolant.
AUSMHLY
Thanks,
Eric (BT7)
Don't believe "no negative history". I wish I could say they are problem free, but no such luck. I had them replace 3 of them. All leaked. Same as you, bottom of the tap.
I gave in and replace with an aftermarket modern drain tap. Problem free as soon as I screwed it in.
(These were all installed on a fresh recorded radiator.)
Photo of what I ended up using.
"The parts falling off my car are of the highest British quality."
Best of luck.
BabaKahawa
Had the same issues.. i also replaced it with a modern drain.
I did keep the old one though.... one of these days I will repair it.....LOL
C
carrottop
Thanks everyone. After reading the replies, I sprayed a little silicone on the original tap to free up the pivoting shaft. Bought a neoprene washer and applied a little teflon tape to the threads. Reinstalled the original and no longer have any leaks. Will return the replacement tap to Moss.
Regards,
Eric
K TR2/3/3A Radiator drain tap? Triumph 4
TRMark TR4/4A Leaking Drain Tap before I could even get the radiator full Triumph 1
Tinkerman TR2/3/3A TR3 Radiator Drain Tap Triumph 2
I Bugeye radiator drain tap help please Spridgets 4
Aldwyn Radiator Drain Tap: Blimey! How do you do it? Triumph 13
A anti-seize recommendations for Radiator Drain Tap Austin Healey 10
H Frozen Radiator Drain Tap Lever Austin Healey 6
S Install drain cock in radiator. MG 2
M Radiator drain plug question Triumph 5
memphis Radiator Drain Valve Austin Healey 18
V TR6 Drain TR6 radiator Triumph 3
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
J BJ8 Radiator Fan Austin Healey 12
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
R TR6 Radiator protection shield differences Triumph 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S For Sale Mg tf new radiator shell-slats-false nose-emblem MG Classifieds 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
edkap2002 TR6 lower radiator hose fitting Triumph 2
nevets Radiator Overflow Tank Austin Healey 23
K TR2/3/3A Radiator coolant level? Triumph 5
D TR2/3/3A radiator overflow restrictor Triumph 9
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
G 100/6 Radiator cross member Austin Healey 6
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
S TR2/3/3A and the radiator was leaking. Triumph 7
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
B Radiator Baffle Installation Austin Healey 4
S Painting a BJ8 Radiator - any advice? Austin Healey 17
S Bugeye Radiator Tank Plug Size? Spridgets 24
FlyingCat Spitfire Electric Radiator Fan Triumph 10
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
