    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR2/3/3A TR3 Radiator Drain Tap
Tinkerman
In my lifetime experience a valve handle running in line with the flow of liquid meant that the valve was open. Crosswise with the flow meant the valve is shut. Not so with my drain tap. I went around and tightened all of the hose clamps and then checked that the valve was closed. It was, based on my lifetime experience definition. Silly boy! I got about half a gallon of coolent in the radiator and my wife, who was with me, suddenly shouted that it was running out. Got the coolent container under it and was able to shut the valve.
Several questions
1: Is handle in line, normal, for that stop tap?
2: The handle feels loosy goosy, like it is not a firm close. Is that normal?
3. Can they be rebuilt or is it new stop tap time?
As always thanks for the thoughts and suggestions.
Tinkerman
1. Yes, like light switches, the British do things backwards to the way we do them on this side of the pond.
2. No, should be relatively stiff to turn. Loose means it will leak.
3. I've done several of them successfully. The usual problem is the spring that holds the moving part of the valve into the body; they tend to rust and fail. I cut a new SS spring from one in the parts bin (or OSH seems to have a good selection of them). You'll probably also want a new flat washer and cotter pin.
The center of the valve is tapered, so you can re-lap it against the valve body to improve the fit. Then clean thoroughly and use your favorite "stop cock" grease.
In an emergency, I've wrapped a worm-drive hose clamp around it, to hold the valve together. Worked great for over a year (until I finally noticed and remembered :smile: )
Since they are such a pain to get to I just soldered mine shut and when I
want to drain the block I just remove it. There is usually enough crud at that part of the block to load the exit anyway.
FRank
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
K For Sale TR3 Radiator Guard Triumph Classifieds 0
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
J TR2/3/3A radiator shield for between the frame of a TR3?? Triumph 4
B TR2/3/3A TR3 radiator removal Triumph 9
T TR2/3/3A Moss TR3 radiator quality?? Triumph 5
B TR4/4A Help on upper radiator support rod parts - what is required on TR3 compared to TR4? Triumph 5
G TR2/3/3A 7 LB Radiator Cap in TR3 Triumph 4
T TR2/3/3A Radiator mounting bolts on TR3 Triumph 16
K TR2/3/3A TR3 radiator L bracket attachment to Rad? Triumph 2
RedTR3 TR2/3/3A TR3 Apron Removal/Radiator Replacement Triumph 10
CJD TR2/3/3A TR3. Radiator Cap Triumph 8
RedTR3 TR2/3/3A TR3 Radiator Triumph 11
B TR2/3/3A 57 TR3 radiator color Triumph 5
M TR2/3/3A TR3 Aluminum Radiator [Wizard] Triumph 18
mrv8q TR2/3/3A TR3 Radiator overflow Q Triumph 4
TRclassic3 TR2/3/3A TR3 Replacement Radiator Triumph 12
S TR2/3/3A tr3 radiator over flow hose Triumph 8
J TR2/3/3A TR3 Radiator Rehab Triumph 9
S TR2/3/3A tr3 radiator Triumph 14
T TR2/3/3A Tr3 Radiator fan loose Triumph 33
E TR2/3/3A TR3 radiator Triumph 0
H TR2/3/3A TR3 Radiator Damage Triumph 7
prb51 TR2/3/3A 4lb. TR3 Radiator Cap Triumph 7
martx-5 TR2/3/3A TR3 Radiator Duct Triumph 3
martx-5 TR2/3/3A TR3 Radiator Mounting Triumph 10
T TR4/4A TR3 vs TR4 Radiator Triumph 2
NickMorgan TR2/3/3A TR3 radiator Triumph 19
C TR2/3/3A TR3 Radiator question Triumph 2
startech47 TR2/3/3A tr3 radiator cap Triumph 11
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 0
W TR2/3/3A TR3 Seat Belts Triumph 3
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
