Frozen Radiator Drain Tap Lever
hundredsixinsf
The lever on the drain tap under my 100-6's radiator is frozen in the closed position. I was going to try flushing my radiator, but I can't get the lever into the open position. Looks like new drain taps are no longer available. I'm guessing I should just unscrew the drain tap from the bottom of the radiator, then hit the lever with some penetrating oil?
Is the drain tap just screwed into the bottom of the radiator or is it welded in?
I'm guessing I'll have the same problem with the coolant drain tap in the block.
john_j
The rotating part a drain taps are often tapered to give a better fit - does yours have a spring on the bottom to keep it tight?
If you, you might be able to get it to turn by tapping it upwards to loosen it, rather than just turning it.
I think normally drain taps are screwed in, so you should be able to unscrew it.
H
hundredsixinsf
Not sure if it has a spring on the bottom, but I don't think so. I'll try to take a photo of it. I think it's just frozen solid from years of storage. I'll try to tap the lever upwards as well. I was trying to pull the lever downward.
Randy_Gay
there should be a little spring - it might be covered in muck. It might be best to remove and soak the tap - the lever can break easily. Work it a little at a time til it frees up. You could also hit it with a wire brush.
John Loftus
As others have said, it's easy to break the handle trying to tap it with force (been there, done that). Since the mating surfaces are conical the spring applies pressure to prevent leaks. Use penetrating oil and then tap carefully on the end that has the spring. You should use this 'gentle persuasion' technique until you can see/feel the part move when you hit the spring end. Once you get it 'broken loose' you can then turn the lever by hand. If it is corroded, you should remove the cotter pin, spring, washer and disassembe the valve. You can then clean up the surfaces with 600 wet sandpaper and use a small bit of anti-seize on assembly.
Removing an old valve from the radiator can be difficult too because of corrosion. Don't use too much force or the threaded insert can spin requiring a trip to the radiator shop (another hard lesson learned /bcforum/images/%%GRAEMLIN_URL%%/cry.gif )
Cheers,
John
Keoke
Yes 100-6 the drain tap is screwed into a brass bushing in the bottom of the radiator. My advice is not to try and free the valve attached to the radiator, remove it take to the bench where it can be safely dismantled and serviced.-Fwiw--Keoke
W Frozen fulcrum pin Spridgets 7
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
Basil Easy[er] way to get frozen brake rotors off Restoration & Tools 13
S BJ7 frozen temperature sensor to block Austin Healey 17
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
C Distributor shaft frozen, but why? Austin Healey 12
Csarneson Frozen Hinges Austin Healey 5
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
Sherlock A Chiva Bus for the frozen north Spotted 4
stuntflyr An October Drive. a photo for those of you in the frozen NE... Austin Healey 16
bugedd Frozen door hinges Spridgets 10
T Frozen head studs Austin Healey 11
RJS Frozen Caliper Piston Triumph 15
J Brake/clutch pedal frozen Triumph 18
F Frozen Clutch Prevention Austin Healey 10
wangdango TR6 '76 TR6 frozen clutch? Triumph 10
I TR6 TR6 frozen brass lower trunion Triumph 3
B Wire wheels: frozen knockoff Spridgets 13
K TR2/3/3A TR3 Lower Bump Rubber Bolt Frozen Like its Welded Triumph 5
R Disassembling frozen brake cylinders Jaguar 5
W Frozen Spring Bolt Removal Spridgets 17
B clutch frozen Triumph 8
PAUL161 Opening locked trunk with frozen lock & lost key MG 3
1 Removing a frozen tie rod locknut MG 15
B Frozen Distributor MG 7
B frozen distributor on 69 mgb Restoration & Tools 3
J Winter Storage - In the Frozen North Jaguar 4
J Frozen E-Brake Spridgets 7
G T-Series Just bought MG TD;engine is frozen;suggestion? MG 13
M Frozen Bonnet Release Despite Warm Weather! MG 8
L Frozen Bolts on Leaf Springs Austin Healey 15
Sherlock Yes... we have some nice cars in the frozen north Other British Cars 9
G Clutch Frozen Austin Healey 27
L Releasing Frozen Nuts & Bolts Austin Healey 22
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
