Bugeye radiator drain tap help please
ichthos
My heater valve is leaking, so I need to drain the coolant. I had my radiator cored/cleaned and it has been sitting for a number of years. I tried using the drain tap the first time. All I am getting is a slow drip. I was thinking of trying to remove the drain tap and installing a new one. It seems to be on very tight. I am worried about ruining the radiator. Any thoughts or suggestions on how I should proceed?
Kevin
histerical
You should be able to unscrew the body of the tap out of the radiator and you will see what needs to be cleaned out with some small drill bits. Also, if you don't have the cap off the radiator, you will get no flow...just a thought.
Bill
jlaird
Worst thing that can happen is that a new drain will have to be installed by a professional.
Think I would start with a wrench and a blow torch handy.
I
ichthos
It is beginning to feel like I am never going to get this thing started. I think what I will do is use the engine drain to bring the level down far enough to repair the valve and worry about the radiator when winter kicks in full time. The drain tap seems to be in there very tight, and if I remember correctly, the bottom of the radiator is brass. It seems like it wouldn't take much to cause damage to this area. Are drain taps standard? I think I have one from my TR6 that would work.
Kevin
jlaird
Drain taps are standard and cheep.
Could just loosen the bottom hose a bit to drain.
S Bugeye Radiator Tank Plug Size? Spridgets 24
pbraun Radiator for Bugeye with 1275 Spridgets 20
6 crossflow radiator with bugeye bonnet? Spridgets 5
P Temp. Probe for 1275 with Bugeye Radiator? Spridgets 21
P Bugeye radiator hoses? Spridgets 5
DanLewis 1500 cc MG Midget Radiator in a Bugeye??? Spridgets 5
DanLewis Taking a chance on a Chinese-made aluminum radiator for my Bugeye Spridgets 74
DanLewis Problems installing Geo Metro radiator into Bugeye Spridgets 12
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
Hairyone bugeye bonnet radiator cowl Spridgets 3
I Bugeye leaking radiator fluid - help please Spridgets 11
R Bugeye radiator ? Austin Healey 2
msoylemez Bugeye sprite radiator brackets wanted Spridgets 1
Ohiobugeye Radiator for 1275 in Bugeye Spridgets 16
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
