    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Bugeye leaking radiator fluid - help please
ichthos
In an earlier post I wrote how I had a big leak between the head and block. Radiator fluid went everywhere. I originally put in a cheap head gasket, and the engine sat for ten years. I took it apart and put in a Payen head gasket. The head had been surfaced. After two weeks I am now seeing two drops near the engine ID plate and a drop near the rear of the head. Do I need to worry? This is starting to feel like the car from heck.
Kevin
Kevin,
Tell us how you assembled the head, down to which bolts and what torque. Yes, you need to worry, because if it leaks now, just think what will happen when the block gets hot and it is trying to fire on all 4.
Scott in CA.
I toqued all bolts in order as shown in my book. I torqued in 10 ft/lb increments each time I went throught the sequence, so I torqued it at 10, 20, 30, and a final torque and 40 ft/lb. By the way, I ran a straight edge over the block before I put in the new head gasket, and it looked fine to me. Someone mentioned in an earlier post that it can leak around the studs, but I don't see how this would make a difference since the head gasket seals around this area. I have installed a number of head gaskets and never had a problem before now. I had to put in another heater valve after I put in the new head gasket, and radiator fluid did seep around the head. How do I know if this is a leak or travelling fluid? Sorry for whoever changed my first post. I didn't know I was breaking the rules by using the word hel#.
Kevin
You might check for leakage at the studs. I have had to put sealant on the threads of the studs themselves when water seeped up the shaft of the stud.
Good call Nelson, that would be my first check also. Along with the heater valve of course.
I am so demoralized by this car. I feel like there is no end to things I have to do to get it on the road. The last problem I found was that the heater valve base was cracked, which I didn't notice it until I added coolant. I replaced it, and there are no leaks there now. I don't see any coolant coming from the studs. If the leak were caused by the studs, wouldn't it be leaking around the studs? I don't want to yank the head if I am not sure if or what the problem is. Is there a way to put the coolant system under pressure to be sure about the leaks?
Kevin
I do believe the studs was something to look at if it wasn't the heater valve.
Personally, I run a bit of stop leak just to seal the little stuff.
General Misunderstanding mandates the use of stop-leak (GM Part Number, too) as the newer ones can drip.
The heater valve probably got cracked removing the head, so it's fixed, don't worry about it.
Check the wiring as directed earlier in another thread and we'll be one step closer.
For some reason, the Most High has blessed you with LBC Tribulation.
Rejoice!
These things, too, shall pass.
And, you'll be a better person for it.
You will be able to help the next poor person undergoing LBC Tribulation with your new knowledge and experience!
No joke!
Dave
Mehheh.
Press on regardless, Kev. Even Jaguar recommends "Stop Leak" in the V-12 engines in the OWNER'S Handbook!!
This is all prelude to better times. Sorting these things can be a daunting procedure but the end result can be a personal pride. Not too many folk will understand the journey you traveled but there are a few of us who've BTDT and know. :wink:
I am glad you found the cracked heater valve. Now move on to other things.
Kevin, take heart. We architects call fixing all the little things at the end of the job "the punch list." In some buildings there are hundreds of items. I think you're doing a great job--you'll get there.
Charlie
Aye, one item at a time and shortly you will be preaty well complete. Never quite make it but that's ok we all have an item or two to work on from time to time.
I know just how you feel.
There have been lots of times over the last 5 years that I've would have been happy to come from work and have the car and all parts gone and a small pile of cash in its place. I'm glad I held that off, though.
Near the end I bought a marker board for the garage, and listed out all the little things needed before I could drive the car. That way, even if the list grew (which it did) I could see progress every time I crossed something off the list.
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
B Bugeye Electrical Diagram with additions Spridgets 6
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
R Bugeye reverse gear Spridgets 6
