POWER WINDOW PROBLEM ON A 2002 XK8
sharjam
Hello;
I am having a problem with the power window on a 2002 XK8. The glass is designed to lower about 1/2 inch when the door is opened. This is so the glass clears the upper weatherstrip. It is suppose to go back up when the door is closed. The glass on the right side will go down just fine, but prematurely will go back up when the handle is released. Closing the door becomes a challenge with the glass in the up position. Any help??
Sharjam
Deleted member 8987
Not sure on the Jag, but on old Lincolns.....there was a switch in the door handle mechanism that tripped a relay to drop a rear window a preset amount.
When the interior lights came on, it latched.
When you closed the door and the interior lights went off, it unlatched the relay and the window went up (as long as you weren't holding a door handle open).
See if your interior lights work off that door.
tiga2
...Have you tried re programing the windows?
Turn ignition to I or II press the down switch lower and hold for 5 sec while down, do the same for up, on each door.
tiga2
...Yup, usualy if you have to do it if you have lost electric power, dead battery or ? It just happened to me BTW.
Deleted member 8987
Interesting procedure.
Just power up, hold the button "down" and when the window hits bottom, keep holding until you hear a "clcik".
Then, run it all the way up, hold the button until you hear a "click".
If that doesn't work the computer is fried.
James123
An older or below par battery often causes this type of problem
Robert Somma power window installation TVR 3
T USB and Auxiliary Power Connections Austin Healey 6
RJS TR4/4A Power (+) Sources Triumph 7
Guido36 Electric Power Steering Austin Healey 2
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
H Loss of Power Upon Acceleration Austin Healey 8
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
JPSmit Power Pack Restoration & Tools 9
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
billspohn Engine Swapping for Straight 6 Power Other Cars 3
I Bugeye lack of power Spridgets 1
R TR2/3/3A Power Steering Triumph 2
Russ80MGB MGB 1980 MGB - No power MG 16
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
AngliaGT Olds,Power Wagon Spotted 1
B Power steering Other British Cars 33
B Intermittent Loss of Electric Power Austin Healey 18
H MGB 1980 mgb no power from ignition switch MG 23
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
M Power Loss Austin Healey 27
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
M TR6 Power Steering Rack & Pinion. Triumph 3
C MGA Where to tap into 12v for a power outlet MG 2
G Power to relays Austin Healey 10
M BN1 Loss of Power Austin Healey 21
S Power Steering Austin Healey 3
M TR6 Adding Some Power Triumph 8
nevets interesting article about converting classic cars to electric power Austin Healey 7
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
UmmYeahOk GT6 Zero acceleration power / Car’s RPMs surge when you get in it. Triumph 40
S TR2/3/3A power wirer for the heater switch Triumph 16
dougie Paddy Power Austin Healey 3
D Lilly under her own power... Austin Healey 7
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
G The Formula Power Fuel Catalyst!???????? Austin Healey 17
tomshobby TR6 power assist for clutch pedal Triumph 12
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
JPSmit DC Power source thoughts Restoration & Tools 11
F 12Volt Bench Power Supply Austin Healey 4
B Power Brake Servo for a 100 Austin Healey 3
R BJ7 wiring power path Austin Healey 21
F BT7 brales poor stopping power - any advice? Austin Healey 19
KVH TR4/4A Engine Power Triumph 10
drambuie Getting more horse power from a Healey 100 Austin Healey 63
AH67 BJ8 losing power and enguine dies Austin Healey 9
L TR6 No power/not enough power to turn signals, wipers Triumph 8
KVH General TR Power Issue on Acceleration Triumph 13
