Power range of "hot" engine
Leibinger
I have a beautiful 62 MKII (BN7) Tricarb centershift, which I wanted to give a little more power. For this purpose, I added a few features, that one normally would chose to improve performance. Those are, amongst other modifications:
• DWR Alloy Head, ports polished
• tubular manifold and “open” exhaust system
• replaced (3) HS4 with (3) HD6 carbs, piston springs and jets according to recommendations of UK Healey Club website (see attachment HD6 Tricarb setup )
• Cosworth pistons, compression ratio is approx. 10.5 to 1
• DWR 8 “hot street” 278 degree cam
• adjustable cam sprocket
• oil cooler
• Mallory ignition
• uprated cooling system
When I had the car dymo tested, it only gave a bit more than 150 HP, with torque approx 235 Nm (174 lb/ft). CO readings were fine the entire range, so it seems the carb settings are correct. Ignition is also set well, as far as I know.
My questions: What power and more importantly torque could I expect to get from an engine set up as described? And where can I start looking for the missing power?
Leo
Hangtown Healey
Re: Power range of "hot" engine
Wow, I did better than that in November with my almost stock BJ8 engine. I will send you my dyno charts. I could tell that mine was sort of running out of breath at a bit over 5000, but I had great torque (180 plus) starting very low down. I would double check your cam timing and calculate if your carbs really flow as much as a pair of HD8's. I think we had best power at 34 degrees ignition timing. I read somewhere that the stock Healey cam timing sprocket was retarded a little bit.
Dave Russell
Yoda - R.I.P
If the car was tested on a "chassis dyno"/"rolling road" it's generally accepted that measured engine HP would be 15% to 20% higher than this number. 173 to 180 HP.
There are friction & heat losses in the drive train & rear tire to dyno roller losses to consider. Other variables are air density & variations in the dyno itself.
I don't think you really have any missing power. Sounds like a great road engine. A good stock engine, on the same test, would likely show something like 120 to 130 HP at the rear wheels.
A quick check, on any engine, at 5250 rpm, HP & torque are equal. Formula -- HP=(TQ*rpm)/5250. The HP & torque curves will always cross at this rpm.
Hangtown Healey
Sorry, I missread. Yes, if the car rather than the engine was tested, the power sounds reasonable.
AJAX50
I have a similar set up except I've got Weber carbs and a John Chatham iron head. On a rolling road it gave 160 at the wheels at 5300 rpm. I'm not sure what loss is typical for a Healey, maybe 20%, so that is 200 at the fly wheel. The engine is quite flexible, but it really flies between 3500 and 5500 rpm, I try to keep below 5500. As mentioned the are other variables such as air temperature and pressure to correct for, but the real test is how it feels on roads you know or in my case will it eat your friends TR6.
L
Leibinger
To clarify the 150HP figure stated above: I meant 150HP at the flywheel, unfortunately. Had it been at the wheels, I guess I would have been happy ...
GregW
Hi Leo,
I'd think you should be getting more power out of that engine. It's a little out of my league, but the ports being polished have me wondering. The link to the UK forum talks about widening the mainfold inlets to accept the HD6 carbs, which would lower the charge velocity. Were the ports widened also? If so, how much?
Dave Russell
Yoda - R.I.P
I agree, 150 at the flywheel is lower than expected. Wasn't sure if you were talking engine dyno or rolling road.
The DWR cylinder head has relatively small but well shaped ports for high intake velocity. Any changes to these ports are likely to reduce power. I would expect the intake manifolds to be smoothly tapered from the carb size to the DWR intake port size.
Unfortunately, ALL parts/systems of the engine MUST be optimized to work together. Intake sizing & mixture, ignition timing, cam timing, exhaust tube sizes & lengths, must all be exactly right to get the expected power.
The DWR8 cam requires pocketing the cylinder block for the exhaust valve heads. If not pocketed, there is danger of the valves hitting the block AND exhaust flow will be seriously restricted. Just pointing out one of the seemingly small items that could seriously reduce power.
At this point, I would take the problem up directly with DWR & go over all aspects of your engine build.
T USB and Auxiliary Power Connections Austin Healey 6
RJS TR4/4A Power (+) Sources Triumph 7
Guido36 Electric Power Steering Austin Healey 2
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
H Loss of Power Upon Acceleration Austin Healey 8
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
JPSmit Power Pack Restoration & Tools 9
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
billspohn Engine Swapping for Straight 6 Power Other Cars 3
I Bugeye lack of power Spridgets 1
R TR2/3/3A Power Steering Triumph 2
Russ80MGB MGB 1980 MGB - No power MG 16
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
AngliaGT Olds,Power Wagon Spotted 1
B Power steering Other British Cars 33
Robert Somma power window installation TVR 3
B Intermittent Loss of Electric Power Austin Healey 18
H MGB 1980 mgb no power from ignition switch MG 23
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
M Power Loss Austin Healey 27
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
M TR6 Power Steering Rack & Pinion. Triumph 3
C MGA Where to tap into 12v for a power outlet MG 2
G Power to relays Austin Healey 10
M BN1 Loss of Power Austin Healey 21
S Power Steering Austin Healey 3
M TR6 Adding Some Power Triumph 8
nevets interesting article about converting classic cars to electric power Austin Healey 7
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
UmmYeahOk GT6 Zero acceleration power / Car’s RPMs surge when you get in it. Triumph 40
S TR2/3/3A power wirer for the heater switch Triumph 16
dougie Paddy Power Austin Healey 3
D Lilly under her own power... Austin Healey 7
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
G The Formula Power Fuel Catalyst!???????? Austin Healey 17
tomshobby TR6 power assist for clutch pedal Triumph 12
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
JPSmit DC Power source thoughts Restoration & Tools 11
F 12Volt Bench Power Supply Austin Healey 4
B Power Brake Servo for a 100 Austin Healey 3
R BJ7 wiring power path Austin Healey 21
F BT7 brales poor stopping power - any advice? Austin Healey 19
KVH TR4/4A Engine Power Triumph 10
drambuie Getting more horse power from a Healey 100 Austin Healey 63
AH67 BJ8 losing power and enguine dies Austin Healey 9
L TR6 No power/not enough power to turn signals, wipers Triumph 8
KVH General TR Power Issue on Acceleration Triumph 13
