Plug for Advanced Distributors
Jimflorida
I had seen Advanced Distributors mentioned in the forum. Just sent my distributor to them and they did an excellent job on refurbishing it. Jim
Disclaimer: I am not a paid celebrity spokesperson. Don't try this at home. Etc. etc.
jlaird
You bet, excellent work at Advance.
RickB
Jeff is great and they do excellent work.
If you want a better than new distributor then send it to Jeff at Advanced.
NFI - just a very happy customer.
T Plug for Jeff at Advanced Distributors Triumph 5
K TR2/3/3A Stripped threads in spark plug hole Triumph 0
C MGB New plug wires and distributor cap MG 10
CARSINC Spark plug thread size Spridgets 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Carlbanan56 MGB Manifold plug MG 5
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Spark plug inspection Triumph 5
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
S MGB mystery wiring plug MG 2
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
PAUL161 T-Series Odd spark plug encounter! MG 10
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Spock TR6 Transmission Plug Triumph 4
D TR2/3/3A Plug Leads Triumph 12
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
K TR2/3/3A Testing spark plug wires..... Triumph 11
B TR4/4A Oil Drain plug size Triumph 14
HealeyRick Plug Your Pipes! Austin Healey 14
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Expansion plug question Triumph 5
M Sump Plug Austin Healey 26
M TR2/3/3A TR3 Overdrive filter drain plug Triumph 7
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
K TR2/3/3A Spark Plug Gap? Triumph 4
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
drooartz Leaking 5-speed drain plug Spridgets 26
J TR2/3/3A Oil drain plug stuck Triumph 10
S Bugeye Radiator Tank Plug Size? Spridgets 24
K Numbered Spark Plug Boots? Austin Healey 27
af3683 TR2/3/3A TR3B Oil Drain Plug Triumph 10
R Plug gap for 907? Lotus 4
Lin Rear differential drain plug leak Austin Healey 16
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
R BT7 engine gallery plug replacement during rebuild Austin Healey 3
jfarris TR2/3/3A Whitworth fill plug for lever shocks Triumph 2
warwick-steve Magnetic Gearbox Drain Plug Austin Healey 28
K TR2/3/3A Plug Weld CyL Head Triumph 10
T TR4/4A Core Plug - Cam Rear change Triumph 7
JimLaney Rocker shaft plug/screw delima Spridgets 3
T Balance Plug Austin Healey 10
