TR4/4A Old Timer
Winston
It's been awhile, I hope all's well with your LBC.
I've asked several I trust and now I'm reaching out to you folks. (I know you're safety minded).
I need to get under the TR4a for an extended period of time safely.
I really can't afford a lift, and the guy's at my Garage are not keen to allow me to put her up on their lift.
I don't weld so I can't build a rig or believe me I would!
Any safe thoughts?
Thanks
Winston
glemon
Jack Stands? Really, just use some common sense in where you place them should be fine, push on the car from a few sides after you have it all set up to make sure it is stable.
TR3driver
Great Pumpkin - R.I.P
Harbor Freight sells some 6 ton jack stands that seem pretty safe to me, if used properly. The frame is welded, the jaw is cast iron, and obviously they are way over-rated for holding up a TR. I've had my old motorhome on top of them, and they showed no signs of distress. They also extend to 24", so there is enough room to work under the car. If you need more room, you can make simple platforms from crossed 2x4s to make them taller.
Of course, depending on what you have for a jack, it may take multiple lifts to get the car that high; and you may need to add some sort of spacer for the last lift.
To double-check, once the car is up on the stands, grab it and try to move it. If it doesn't feel solid, adjust the stands as necessary until it is.
Oops, forgot the link. They are even on sale at the moment!
https://www.harborfreight.com/6-ton-steel-jack-stands-61197.html
Geo Hahn
I don't know what the British car club scene is in Des Moines, but in Tucson our club has garage days several times a year at a member's garage that has a lift. Members sign up in advance for time on the lift -- no major projects, clean up after yourself and at the end of the day any non-runners get pushed to the curb.
It's a great chance for members to take care of lube jobs, exhaust system adjustments, gearbox oil changes or just check things out under there.
Failing that - yeah, good jack stands are the way to go, lots of pros use them. I always leave the jack itself in place (if it isn't in the way) and if the road wheels are off I slide them under the frame (just for luck).
When I'm working in the garage my wife pops in every half hour or so just to say 'Hi' -- but I know she's really checking to see if anything bad has happened. Good to have someone worrying about you.
glemon
For me it sort of depends on the project, if she hears a lot of pounding and swearing she has learned it is best to stay away...
charleyf
One more precaution that you may be able to use if the tires are left on the car you can slip the spare tire under a wheel as an additional safety item. But like the others have said good jack stands plus leaving the jack under the car should provide enough margin of safety.
charley
Kleykamp
At one point I had a set of ramps. The car was too low to run up the ramps but I would jack it up and put the ramps under the wheels. Always felt very secure with that setup. I even raised the other end on jack stands and still felt secure. Been thinking about buying another set. Jack stands seem OK but the relatively small tripod base always gives me room for concern. Also, just remember that the higher you go the less stability you will have.
DNK
Winston , If your 4 is a solid axle. It even makes it easier
glemon
Had the same thought, jackstands always seem to fit sturdy and snug under a live rear axle, but if you look at the bottom of Winston's post it says "IRS"
pdplot
Under NO conditions ever use a cinder block. Never. I repeat - never. Good solid jack stands are the way to go and if possible, I leave the jack under the chassis as well. A guy near me got killed working under a deSoto when it fell on him. Another word of advice from an 80-year old. Beware of springs - any kind of springs, small, large. Know what you're doing and what the spring will do when you release the tension.
TR3driver
Amen !
I was lucky, not under the car at the time. But there was no impact involved, no warning of any sort, it just crumbled to gravel instantly.
Vila
It depends on what I am doing.
If the wheels need to come off I use my jack stands, but if I can leave the wheels on for the job I am doing then I use my ramps.
I friend of mine developed the plastic Rhino Ramps years ago then sold the manufacturing rights and when they had them tested they exceeded the recommended maximum weight limit by several time. Also, a TR4 is no where near the max recommended weight for the ramps. They lift the car approximately 8 inches and work from both the front or back on a TR4.
I have also used both on occasions. I will drive the back wheels up onto the ramps then jack the front end up and put it on the jack stands. By setting the emergency brake prior to jacking up the front end, the car seems a lot more stable then when I use jack stands on all four corners.
Vila
1933 Chevrolet
1962 Triumph TR4
1984 BMW 633 CSi
TR3driver
Thanks, Mike. I didn't have a photo handy. Here's a direct link to one of them.
W
Winston
Thanx to all who chimed in, I've not yet put her in the air but have decided 4 new Heavy Duty jackstands with pins versus notched posts.
mctriumph TR2/3/3A Old trick on SU's Triumph 5
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
K TR2/3/3A Old school battery shut off switch....... Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
K TR2/3/3A Old school penetrating oil? Triumph 24
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
S TR2/3/3A old 4 bolt axle differential. Triumph 11
R Old History - List of USA TVR Authorized Dealers TVR 10
Popeye General TR Old robbins top in box Triumph 7
dougie Pistons - Old vs New Austin Healey 12
B Help for Old Men Restoration & Tools 15
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
roscoe New / old hard top Austin Healey 16
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
D Removing Old Radio Austin Healey 4
Bob Claffie New old car Other Cars 7
Mark Bailey Old tire rule? Restoration & Tools 5
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
T TR2/3/3A Question on old radio from my TR3 Triumph 9
DrEntropy Looking thru old pix Other Cars 8
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
B Dodge Chrysler Cool Vanilla = Old English White? Spridgets 7
R How old is "dead" FORUM Navigation Questions 5
D General Tech Old gasoline disposal Triumph 17
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
tinman58 General Tech Why I love old cars Triumph 1
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
B TR6 New [Old] Member Triumph 2
M Old English White Paint Code for early BE Spridgets 1
E Trying to ID some old classic car gauges Restoration & Tools 2
Zitch For Sale TR4 - old door cards Triumph Classifieds 0
AngliaGT Cool Old Truck + Spotted 1
D TR2/3/3A Recondition old wire wheels or buy new? Triumph 10
jfarris "Old Yeller II" Spotted 3
anarchy99 Help with new [old] Sprite hardtop Spridgets 17
CessnaTPA New Tires or Keep Old Ones Austin Healey 36
AngliaGT My Old Ford Consul Capri Other Cars 0
Answerman Restoration of OLD [pre WWII style] leather seats Restoration & Tools 5
jdubois Wanted Old BMH Original Technical Publications CDs Triumph Classifieds 0
doc50 New old member. Spridgets 43
doc50 New Old Member...sort of. Spridgets 7
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
S TR2/3/3A On those old original coils Triumph 2
D never throw old parts away.... Austin Healey 7
simon1966 Eclipse Day Photos, back to her old color! Austin Healey 2
JimLaney Liquids for 50 + year old Sprite Spridgets 5
