OIL PRESSURE GUAGE
jet_jockey
Hello All,
I am finding this forum quite useful as a new 1969 2+2 owner. I have a new problem someone may shed light upon.
When I turn the key on, the oil psi guage goes to maximum pressure with engine not running. I discoverd the ground wire to the sender unit was not grounding however, upon repairing that, the problem persists. Could that errant grounding have damaged the dashboard gauge? Are there tests to isolate the defective unit before I begin replacing the guage and sending unit?
Greg in Montana
Deleted member 8987
Ground wire to the sender? Oil pressure?
Should be one send wire from sender to gauge. If you unplug the wire, insulate it from grounding, key on, and the gauge moves, either the wire is wrong, insulation gone somewhere and shorting, or gauge unit itself is shorted at the load end.
The test you are looking for is, sender unit wire unplugged, key on, gauge zero. Wire shorted to ground, key on, at least 60 and probably pegged.....don't do it for any longer than it takes to get to 60.
If the gauge works as those tests indicate, gauge unit is good. If you then plug the wire onto the sender and it pegs with key on, sender is bad.
Dave
HEALEYJAG
THe sending units are notoriously BAD.. Had to replace them over the years 4 times.
Pete
Deleted member 8987
True, but until the results of the testing are in, we aren't going to condemn it.
LarryK
TOC is right, test first, spend your money later on the right part. Saves $$$$ in the long run.
J
jet_jockey
Thank You Davem, Larry Pete and TOC;
In furthur research I find only "Terry's Parts" offers a replacement sending unit and the picture shows two terminals on it as mine has. None of the wiring diagrams show the sending unit. Perhaps I have a sending unit from a different unit. Perhaps also, the second terminal was an attempt to "fix" previous faulty units.
I shall remove the wire from the sending unit to the guage and replace it with a jumper. If the gauge still goes to full pressure I will replace the sending unit.
Sounds like a guy cannot have too many sending units. Ha
Thanks againg Gentlmen,
Greg in Montana
Deleted member 8987
Power from ignition switch usually through a voltage stabilizer goes to one side of the gauge. The other side of the gauge goes to the sending unit.
If you have a dual-purpose sender, with idiot.....errr.....red warning light AND actual gauge, then maybe two wires on the sender, and maybe crossed up.
No jumpers needed on anything for first part of the test.
Unplug sender completely, turn ignition on, what does the gauge do?
J
jet_jockey
The errant oil pressure gauge problem has been solved. Evidently the last owner connected one of the oil pressure sending units terminals to ground. The ground did not ground so the sending unit worked as it was supposed to. At some point the ground must have made a connection causing the guage to read full pressure. By removing the errant ground the gauge works like it is designed to do. Thank you all for the good advise.
G Oil pressure guage shows no oil pressure! Austin Healey 5
tony barnhill '63 Midget Engine to Oil Pressure Guage... Spridgets 8
jlaird Water temp/oil pressure guage Spridgets 3
Tinkerman TR2/3/3A Oil Pressure Guage Line TR3 Triumph 3
T Oil Pressure guage.... Spridgets 18
S oil pressure guage replacement? Spridgets 6
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Oil? Oil Pressure? Triumph 8
JFS TR6 No oil pressure Triumph 2
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
T TR6 Low Oil Pressure Light Triumph 3
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
K Time to build oil pressure Austin Healey 23
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
D BT7 oil pressure relief valve Austin Healey 19
D BT7 oil pressure relief valve Austin Healey 2
J Zero oil pressure at 4000 RPM Austin Healey 24
D TR2/3/3A oil pressure Triumph 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
S An oil volume question and an oil pressure question Austin Healey 5
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
B TR2/3/3A normal oil pressure in TR3 Triumph 6
