Oil Capacity
healeyboz
The sump capacity calls for 7.8 pints for a 1275. I am assuming this is with a dry oil filter? Am I correct?
That is correct, and the filter capacity (if stock) is 1.2 pts.!
Thank you sir. The oil filter is spin on. I imagine it is less that 1.2 pints. Probably too close to make a difference.
The filter that I am running right now is the black one that VB sells with their spin on kit.
P.S. Spin on kit did not fit. So I stole a spin on adapter from one of my dad's old mini race engines. LOL. I told him about it and he said that he got it through Mini Mania years ago. Probably in the 70s of course. They still sell them for about $100. I wish I would of known about them before I bought the VB version.
Got one if anyone wants it!!
I find it easier with Bugsy just to unbolt the adapter itself rather than trying to get a filter wrench in there. For some reason I can't find a good angle on the filter.
Jim, if you are using the angled adapter, there are band type filter wrenches that take a 3/8" drive. Using a long extension and ratchet, you should be able to get it from the top.
Jeff
The oil cooler was an add-on for 1275s and would not have its oil content included in the capacities!
How tight are you guys making the oil filters? All you need is to put it on snug, and then 1/2 to 3/4 of a turn more!
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
PAUL161 MGB MGB Transmission Oil Capacity ? MG 2
A 100-4 oil capacity Austin Healey 3
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
B Aluminium sump and the effect on oil capacity Austin Healey 8
R Differential Oil Capacity Austin Healey 10
R # qts of oil, Capacity of radiator healey mk II BJ7 Austin Healey 8
H TR4/4A TR4 Oil Capacity Triumph 20
V Oil capacity of Datsun gearbox Spridgets 1
jvandyke oil capacity Spridgets 4
J TR2/3/3A TR3 Oil Capacity Triumph 7
healeyboz oil capacity Spridgets 1
P TR6 TR6 Oil Capacity? Triumph 7
davidk TR6 Transmission Oil Capacity on a non OD TR-6 Triumph 5
B Oil Capacity 3000 Austin Healey 36
msoylemez datsun 210 trans oil capacity Spridgets 4
jsneddon TR2/3/3A TR3 Transmission Oil Capacity Triumph 3
jerrybny Oil capacity after spin on adapter conversion Triumph 2
T GT6 Help on GT6 oil capacity Triumph 8
P Oil sump capacity Austin Healey 7
J Oil capacity MG 3
G Oil Pressure Slow to Rise Austin Healey 6
KVH General Tech I’m Guzzling Oil One Year After Rebuild—Blowby? Triumph 8
T Wanted MGB Coil Over Front Suspension MG Classifieds 0
T TR2/3/3A Changing oil filter Triumph 3
D 1953 Riley 2.5L Help, Oil Filter Location Other British Cars 2
C TR4/4A Oil pan removal and replacement Triumph 27
Ohiobugeye cOIL qUESTION Spridgets 5
T General TR Easy oil leak ID Triumph 9
drooartz MGB Fuel in the oil MG 5
AUSMHLY Dashpot Oil Austin Healey 11
T TR2/3/3A fuel pump oil leak Triumph 7
D T-Series MGTD Oil Leak? MG 2
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 2
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
wkilleffer MGB Coil resistance MG 4
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Cokerair TR4/4A Fried Ignition Coil Triumph 18
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
