Off to British Car Day
drooartz
Do us proud JP. :cheers:
Rut
Looking real good JP!
Rut
AngliaGT
But WHERE will you put the trophy?
JPSmit
JPSmit
No prizes this year - which is fine - there is no judging just people registered for the show picking their favourites. I think it often has to do with how many people you know.
Possibly a record attendence 1000 plus cars - the weather was actually on the hot side for September. I didn't take a lot of photos, but, this was my very favourite this year: Riley
Untitled by John-Peter Smit, on Flickr
I also loved this one Austin 7
Owned by the owner for 20 years and his mother (or grandmother) for 30 years before that. Unrestored.
and bizarrely a couple of hondas showed up - so tiny - so pretty.
JPSmit
JPSmit
Some interesting cars this year (every year) about 18 Deloreans - TVRs - a Rover 8 (very unusual) and at the other end of the scale 3 new McLarens.
a good day was had by all
JPSmit
JPSmit
On a related note, Ms Triss has not been running especially well for a while - we have discussed this elsewhere, on Saturday I replaced a fuel filter, a dodgy plug wire, and the plugs themselves - they were a bit sooty in part because I have been running it with some choke as the idle has been a bit low (500 rpm instead of 800) Was discussing this whole thing with my mechanic who gave me a can of Mopar engine cleaner - much like Seafoam I suspect. Was supposed to spray the can into the carb, shut off the engine and let sit for 3 hours. Did more or less as instructed - and what a difference! Too my ears (and even Ms JP's ears) it ran stronger and more solidly.
I realize it is at some level a liquid version of an Italian tune up, but, I have driven so little in the last few years that I think it just got clogged up. Will keep you posted but seems like a good solution for low mileage driving cars.
K TR2/3/3A Old school battery shut off switch....... Triumph 3
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
B TR4/4A Headlights Blink Off Triumph 15
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
Editor_Reid Knock-Off Hammer Austin Healey 8
kodpkd Signing Off Austin Healey 8
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
T Knock-Off Spinners Austin Healey 43
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
G Engine Will Not Turn Off Austin Healey 10
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
T TR4/4A Fenders off the car for paint? Triumph 8
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
R Turn Signal Knob goes off center Austin Healey 9
J BJ8 flywheel take some pounds off Austin Healey 17
A Setting Camber Really Off Austin Healey 13
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
JPSmit So I guess I don't need to lay off the churros after all Spridgets 4
S TR2/3/3A Frame off vs. body on restoration Triumph 21
Basil Easy[er] way to get frozen brake rotors off Restoration & Tools 13
B TR4/4A Can't get rear extension off. Help! Triumph 24
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
JPSmit Off to bed for the winter Spridgets 10
TomMull Knock Off Tool Restoration & Tools 6
S MGB When your breaks off. who ya gonna call......? MG 2
L Tight spot on steering box is way off Austin Healey 18
R TR4/4A Speedometer off 10mph Triumph 6
Boink MGB MGB-GT off-roading? MG 4
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
J Gas pump auto shut off question Austin Healey 2
Got_All_4 TR6 How does this steering lock come off Triumph 9
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
Got_All_4 TR6 Rear Panel Reflector off a parts car? Triumph 8
D TR2/3/3A off topic , but can you help with a quotation Triumph 5
T TR4/4A Heater control valve - cant completely turn off Triumph 3
D cut-off switch Austin Healey 20
D TR2/3/3A curious tachometer take-off Triumph 5
Joe Schlosser Transmission Tailshaft housing off center Spridgets 3
Jim_Gruber New Shoes, New Shoes Bugsy got to show off his new shoes today. Spridgets 6
jfarris TR2/3/3A Off the shelf oil filter Triumph 9
A turn signal knocked off center Austin Healey 14
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
CJD TR2/3/3A Knock Off Differences Triumph 13
S TR2/3/3A bezels off the switches Triumph 5
Jim_Gruber BE Gauges and Speedhut - Is it a 3 3/8" Gauge???? now 20% off Black Friday Sale Spridgets 10
