Gas pump auto shut off question
jman15
When filling up the gas tank on my Healey the gas pump auto shut off doesn't seem to work. This results in some gas spilling out over the trunk area. Can't figure out why this occurs as even filling up a gas can will cause these pumps to shut down when full. I have a standard Healey gas tank, neck and cap. Any idea why this happens or what I can do to prevent it?
roscoe
The auto shutoff on gas filler nozzles depend on a venturi in the gas flow path and a sensing line that ends just inside the end of the nozzle. The venturi creates a bit of a vacuum as the gas flows through it and it causes a small stream of air to be sucked up the sensing line. As long as the fuel doesn't reach the end of the sense line a diaphram controlled shutoff valve allows the gas to flow. As soon as the nozzle tip is immersed in the rising gasoline the diaphram valve cuts off the gas flow due to the change in pressure in the sense line due to it pulling gas instead of air.
If that system doesn't work for your Healey it can only be because the fuel level rises in the filler neck and the nozzle is at such an angle or position that the sense line tip isn't being immersed. I'll bet if you carefully fill the tank and slow down, maybe way down, before the fuel rises into the narrow neck of the tank, that the shut off will work. Also, if you look into the tip of the nozzle and see where the sense line is you may be able to better position it so it sees gas earlier as it rises in the filler neck. Even knowing this and trying to make it work I put a towel around the base of my filler because it is in the boot (BN2) and I dont like gas seeping around.
mgtf328
Mine does the same thing. I think it's because the filler neck is so long and the top of the tank is flat. The displaced air has nowhere to go when the tank reaches the full level, and the fuel is coming in so fast it blows out before the nozzle can react. Anyway, I watch the pump gauge and when I get near the full state I slow the pump down and can usually get more fuel in the tank without the blow back.
AJ
longbridgehealey Fuel pump racing, no gas Austin Healey 26
I TR6 Gas pump problems. Triumph 7
longbridgehealey Gas pump for 1275 Spridgets 20
M TR4/4A TR4 Optimal Compression - 91 Octane Pump Gas Triumph 13
J New SU Fuel Pump - Gas leaking out of carb vents Austin Healey 24
rlich8 Fuel Pump & Gas Line fittings Triumph 5
Walk New Fuel Pump & Rebuild Carb - No Gas in Between! MG 21
Westfield_XI Maximum compression ratio for A-series on pump gas Spridgets 14
L Gas Cap Recommendation Austin Healey 1
Celtic 77 MGB LeMans Gas filler MG 10
mctriumph General TR NEVER start a car with stale gas Triumph 0
TomMull GT6 Gas Tank Outlet Triumph 0
B TR6 Gas on spark plugs Triumph 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
Celtic 77 MGB Pessimistic Gas gague MG 10
B gas leak underneath the carburetor Restoration & Tools 2
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
LAW75 Concours: Original Gas Hose Austin Healey 12
LAW75 Gas Odor Elimination Austin Healey 3
B TR4/4A GAS TANK FELT Triumph 14
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
edkap2002 TR6 gas smell Triumph 8
R TR2/3/3A Gas pedal pad for TR-2 Triumph 3
B Damaged threads in the gas tank Austin Healey 7
BierRunner TR6 TR6 Gas Pedal Triumph 4
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR4/4A Gas Tank color? Triumph 4
B BE vs. Later Model Gas tanks Spridgets 2
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
J For Sale Triumph Tr 2/3 Gas Pedal Triumph Classifieds 1
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
D What's inside the gas tank?? Spridgets 13
C TR2/3/3A Gas Line Triumph 11
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
S TR2/3/3A TR3 gas filler cap Triumph 1
J TR2/3/3A TR3A gas tank repair Triumph 7
Rut MGB Running out of gas symptoms MG 21
T TR2/3/3A TR3A Gas Cap Triumph 15
D Gas Pedal Pad Jaguar 7
