New Tiew Rod Ends. Paint Black Y/N
Jim_Gruber
Painting my steering rack. Didn't realize it's all Brass under there. At least the one on Bugsy IV is. So do I paint the new Tie Rod Ends y/n. Thinking Yes
And man were the old Tie Rod Ends really shot.
Rut
Jim,
Paint everything you don't want to rust!
Rut
Jim_Gruber
Jim_Gruber
Agreed Rut
Jim_Gruber
Jim_Gruber
Project tonight, mask, prime, paint Tie Rod Ends, Coat of Gloss Back on the Rack to cover up primer. I'll have to take a picture of my Custom Made - Steering Rack Paining Fixture. Consists of a piece of twine attached to the steering rack hanging off the end of my 5' Step Ladder. Works great. Spin the Rack and paint all sides at the same time. Necessity is the Mother...!
B Rod & Main Bearings Recommendations Austin Healey 10
W Correct Tie Rod Ends Spridgets 0
D Separating the piston from the connecting rod. Spridgets 9
KVH General Tech Connecting Rod Bearings Triumph 8
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
A MGB MGB 1974 windscreen centre rod replacement MG 5
S For Sale TR-3 Tie Rod Assembly for Sale Triumph Classifieds 0
DrEntropy Shift rod seal in an automatic? Jaguar 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Healey Nut Cross Rod Correct Length Austin Healey 14
7 General TR Hot rod Triumph 0
Healey Nut BT7 Panhard Rod Austin Healey 28
Walter74 Steering Rod Installation Austin Healey 6
red57 Rod Bearing Clearances Austin Healey 4
BoyRacer Odometer Reset Rod Austin Healey 4
K TR2/3/3A Removal of tie rod end? Triumph 7
TRopic6 For Sale Vandervell .010 Rod Bearings, MG TB, TC, TD, TF [Partial set] MG Classifieds 0
R TR2/3/3A Throttle rod spring location Triumph 3
I Brake rod questions Spridgets 7
Y MK V rod bearings Jaguar 1
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R Connecting Rod Big End Specification Austin Healey 4
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
T TR6 Air vent rod connection Triumph 1
F TR2/3/3A Throttle linkage cross rod Triumph 4
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 2
K Wanted TR3 Tie Rod Sleeve Triumph Classifieds 2
Rhodyspit75 Bugeye bonnet prop rod Spridgets 2
Michael Oritt Center rod, bracket and mirror info needed Spridgets 8
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
M TR2/3/3A Connecting Rod Locking Tab Deformation Triumph 15
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
Got_All_4 TR2/3/3A Inner tie rod ends Triumph 4
K TR2/3/3A SU horizontal carb linkage rod? Triumph 3
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
PeterK General TR Need a handbrake button and rod TR4a-TR6 Triumph 5
R Upgraded rod bolts for stock rods Austin Healey 1
D TR2/3/3A tie rod end Triumph 17
D TR2/3/3A 7.68, outer tie rod Triumph 4
D connecting rod stamps Austin Healey 1
Feathers 289I inner tie rod end. TVR 0
KVH General Tech Steel Wool on Rod Bearings Triumph 9
KVH General Tech Plasti-Gauge on Rod Bearings Triumph 13
S TR4/4A Fascia support and shift rod boot Triumph 0
