TR4/4A New [old] TR4 crankshaft, bearings?
Alan_Myers
Hi all,
Well, I was pretty nervous buying a 40 year old crankshaft off eBay! Cost more to ship than to buy, but overall a very reasonable total.
Yesterday it arrived via UPS Ground... The replacement I plan to use in my TR4. The idea is to have it reworked and ready to go, along with a matching set of bearings, before the engine is even pulled so that the rebuild can be done as efficiently as possible.
I'm breathing a sigh of relief... This crankshaft is in surprisingly good shape! Must have come from a low mileage car, and one that was babied at that, with frequent oil changes and such. All seven journals have no detectable ridges or wear marks, are totally smooth.
Might even be able to use it "as is", but I'll reserve judgement until it's properly and completely checked out by a machine shop. I'm just using dial calipers, which seem to show everything within the "loose" tolerance, such as might be used in a race motor that doesn't get any break-in time.
Of course, this is a street car that *will* see normal break-in and it might be wise to go ahead and grind to .010" over on everthing anyway.
We'll see after the crank is more carefully miked by a shop and checked for any out of round too. (My good measuring stuff was stolen some years ago and never replaced since I'm not doing machine shop work any more.)
This crank will be going to a machine shop anyway. At a minimum, it needs to be cleaned inside and out, throughly crack-detected, modified for a "modern" rear oil seal and additonal flywheel bolts, then possibly have the journals hardened.
Questions:
What currently available main and big end bearings are folks using and recommending? Sources? I am finding a pretty limited selection out there for the 4-cylinder TR motor, mostly bi-metal although I've always heard a tri-metal bearing was better in this motor. In the old days, Vandervell (sp?) were the ones to look for, but they seem largely unavailable. Thoughts and opinions?
Assuming the crank gets reground, or maybe even if it doesn't, what do you think about hardening the journals, probably nitriding? Also, what do you think about shot-peening the rest of the crank, or any other process? Worthwhile?
Note: This motor should redline around 6000-6200 rpm once it's done. It's being built and set up more for low/mid range, such as autocross and street use, rather than a high revving, road race screamer (in which case I'd be saving up for a new billet crank$$$$haft).
Your thoughts, opinions and recommendations would be very much appreciated!
Cheers!
Well, this is interesting...
Searching the Internet for info, it looks like AE, Vandervell, Glacier, Clevite and maybe even some other old name brand/bearing manufacturers are now all owned by Dana Corporation!
Alan,
TRF did have a small cache of Vandervell crank bearings left over as of recently. You might make a call to Charles or Dave and see if they are still there and if so, will they sell them.
Bill
Alan there has been a lot of discussion on the Friends of Triumph racing board about this recently.
The conclusion was that Vandervell, if you can find them, would be first choice, and that "King" bearings, made in Israel, werte also giving good results. I will check the thread again, but I think Glacier were found inferior for more highly stressed engines.
Also, given the rpm you are contemplating, nitriding or cryogenic treatment of the crank might be worthwhile. I am no metallurgist but understand there are different ways of doing both these processes involving different temperatures and durations in order to harden to different depths.
It appears that a properly done cryogenic treatment changes the crystalline structure of the metal from austenitic to martensitic, thus strengthening the bonds between the crystals.
Worth doing some research on; though not necessarily a "magic bullet".
Let us know how it works out!
Simon.
Zitch For Sale TR4 - old door cards Triumph Classifieds 0
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
boeingpilot TR4/4A How to track down my dads old TR4 Triumph 8
TR6oldtimer TR4/4A I'm quiting my decades old TR4 restore project. Triumph 12
mctriumph TR2/3/3A Old trick on SU's Triumph 5
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
K TR2/3/3A Old school battery shut off switch....... Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
K TR2/3/3A Old school penetrating oil? Triumph 24
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
S TR2/3/3A old 4 bolt axle differential. Triumph 11
R Old History - List of USA TVR Authorized Dealers TVR 10
Popeye General TR Old robbins top in box Triumph 7
dougie Pistons - Old vs New Austin Healey 12
B Help for Old Men Restoration & Tools 15
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
roscoe New / old hard top Austin Healey 16
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
D Removing Old Radio Austin Healey 4
Bob Claffie New old car Other Cars 7
Mark Bailey Old tire rule? Restoration & Tools 5
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
T TR2/3/3A Question on old radio from my TR3 Triumph 9
DrEntropy Looking thru old pix Other Cars 8
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
B Dodge Chrysler Cool Vanilla = Old English White? Spridgets 7
R How old is "dead" FORUM Navigation Questions 5
D General Tech Old gasoline disposal Triumph 17
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
tinman58 General Tech Why I love old cars Triumph 1
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
B TR6 New [Old] Member Triumph 2
M Old English White Paint Code for early BE Spridgets 1
E Trying to ID some old classic car gauges Restoration & Tools 2
AngliaGT Cool Old Truck + Spotted 1
D TR2/3/3A Recondition old wire wheels or buy new? Triumph 10
jfarris "Old Yeller II" Spotted 3
anarchy99 Help with new [old] Sprite hardtop Spridgets 17
CessnaTPA New Tires or Keep Old Ones Austin Healey 36
AngliaGT My Old Ford Consul Capri Other Cars 0
Answerman Restoration of OLD [pre WWII style] leather seats Restoration & Tools 5
jdubois Wanted Old BMH Original Technical Publications CDs Triumph Classifieds 0
doc50 New old member. Spridgets 43
doc50 New Old Member...sort of. Spridgets 7
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
S TR2/3/3A On those old original coils Triumph 2
