Need bugeye wiper motor help please
ichthos
Not a good day - no progress on my punch list. One of the various things I tried to fix was the wiper motor. The original wire was rotted from the motor to the "can". The fist time I soldered in a new wire it was too short. I got it to work, but then found I couldn't adjust the can far enough. I took apart the wiper motor again to solder in a long enough wire so that the "can" top would be able turn, enabling me to fix where the wipers stop. Now that it is back together, it doesn't work. There is power to the motor. I am stumped. Any ideas on where to start?
Kevin
If there is power to the motor and you're sure - check for ground.
Check continuity and solder joint of new wire
Basic troubleshooting: apply power and check for voltage at each point with a test lamp or voltmeter. You'll find the problem in maybe five minutes. Take a good look at the switch. If there is voltage on any switch terminal when it is on, the switch is bad.
The switches on these cars are notoriously underrated, and carry a lot of current. As a result, the contacts get fried fairly quickly.
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
B For Sale 1959 Austin Healey, Bugeye Sprite with 74k Miles Price Drop- NEED TO SELL Spridgets Classified 0
R Need Advice On Refinishing A Bugeye Hardtop Spridgets 15
Steve P. Need Bugeye vin tag & title Spridgets 15
W Likely need a few Bugeye inner body panel parts Spridgets 0
P Inherited 59 Bugeye need help. Spridgets 26
DanLewis How bad does your Bugeye need a boot? Spridgets 6
I Need some advice on bugeye conversion Spridgets 8
rkep01 Need stock Bugeye seats Spridgets 10
J Need Bugeye top frame; Have older Sprite top frame Spridgets 21
BugeyeNJ58 Need a Better Muffler for 59 Bugeye Spridgets 5
M Need bugeye part Spridgets 6
T Anyone need Bugeye floor patch? Spridgets 2
I Bugeye heater cable almost repaired, but need help Spridgets 4
I Bugeye bonnet gaskets - do I really need these? Spridgets 10
I Bugeye - need help with last 3 dash wires Spridgets 7
M Desperately Need a Pair of Hood Stays for Bugeye Spridgets 3
M I Need Bugeye Parts Spridgets 1
M Need Bugeye moved in SW FL to SC Spridgets 4
TexasSprite Anyone need seat back pads for a Bugeye? Spridgets 0
djk need rollbar for bugeye Spridgets 23
ncbugeye Need immediate help with Bugeye fuel tank Spridgets 10
Shealey Need a photo of a unmolested dash. 58/59 bugeye. Spridgets 25
S Need a Bugeye Bonnet Spridgets 1
Team_Sprite We need to look at a bugeye that's together Spridgets 3
S Need New Bugeye Bonnet Spridgets 2
jlaird Need some info on a Bugeye Spridgets 9
Y MGB Do I need a heater valve? MG 1
V Wanted What cars used this trunk latch? I need one! Other British Classifieds 2
AngliaGT '97 Miata - Need to Replace the EGR valve - recommendations? Other Cars 7
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 4
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
