    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
mystery Shorrock supercharger- what car ????
beaulieu
aeronca65t
Re: mystery Shorrock supercharger- what car ????
I clicked on those links.
Message said "cannot be viewed".
[edit-OK. Works now.]
coldplugs
Platinum
beaulieu said:
...anyone know what this Shorrock supercharger fits , I cannot recognise the intake port pattern ...
XPAG maybe? (MG TC->TF 1250)
Looks like one we had. I have photos but no measurements. The intake manifold on the blower took a single SU of 1.5" dia iirc.
beaulieu
beaulieu
I think the intake ports on those early MGTCs had the bolts going up and down over the intake port ,
where this shorrock has the mounting bolts to the side.....
Beaulieu
PS....or maybe I am wrong .....
coldplugs
Platinum
beaulieu said:
I think the intake ports on those early MGTCs had the bolts going up and down over the intake port...
I dunno. It's been a while since I looked at one. Anyway, here's a photo of ours that (barely) shows the output manifold. (Lower right in the photo). The ports seem centered over the end of the blower housing, as are yours, and the fastenings seem to be at the sides. I don't have any better shots of the unit handy.
Deleted member 3577
Here is an E-bay one right now.....
(This probably isn't helpful but, it is a vintage supercharger)
I would like to try one out in the Elva sometime also.
And an original HRG/Derrington X-Flo headed engine w/ Webbies.
And a twinkie engine.
And a......?
https://cgi.ebay.com/ebaymotors/MARSHALL-...1QQcmdZViewItem
beaulieu
beaulieu
ummm OK....so not an MGTC-TD
I wish I had a book with intake gasket pictures !
Beaulieu
aeronca65t
Actually, based on the last picture I posted, I was implying that it *would* fit an XPAG MG engine.
Here's another (poor) picture, but it looks like it might fit an XPAG based on the layout.
Roger
Bronze
I'm almost certain it's for an Austin Seven - 750 sidevalve. Rectangular ports etc.
coldplugs
Platinum
You may need to find someone to do some measurements. The Moss catalog illustration shows that the XPAG head has two rectangular ports with fasteners on the sides, laid out with their long sides horizontal. I'm not sure about the Austin Seven but I think superchargers for these would be pretty rare in this part of the world. Blowers for MG's were pretty common in the fifties in the US.
Grantura_MKI
Austin sevens did not use a long snout blower unit. I have several Shorrocks...will have a look to see if I can sort it out for you.
Cheers, David.
Roger
Bronze
Depended where you mounted them. If under the manifolds, alongside the crankcase in the same place as the blown Ulster, which is exactly where a blower like the one illustrated would mount, they would have a long snout. Otherwise you'd never get a drive to them.
Been there, done that . . .
K TR2/3/3A Mystery TR Part Triumph 9
Celtic 77 MGB Mystery cylinder head attachment. MG 4
A For Sale Mystery brass intake manifold Other British Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
equiprx Mystery part Other British Cars 2
BoyRacer Austin A90 mystery engine British Motor Corp 2
V MGB Mystery fastener from '66. Did I miss something? MG 6
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
BoyRacer Mystery 3000 Engine Block Austin Healey 2
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
D TR2/3/3A Another mystery part(s) Triumph 2
S MGB mystery wiring plug MG 2
jehuie Morris Minor horn mystery British Motor Corp 12
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
D TR2/3/3A Another mystery part Triumph 8
Sixpack TR6 Horn Mystery Triumph 3
M TR6 Mystery Switch Triumph 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
J TR2/3/3A TR3 gas tank mystery Triumph 5
M TR6 Fuse box wiring mystery Triumph 9
S MGB mystery wire MG 32
somewhatspritely Mystery Screws Spridgets 5
Healey Nut Mystery Part Austin Healey 2
D TR2/3/3A Another mystery part..or two Triumph 14
B 2013 Nissan Frontier front end mystery Other Cars 7
B MGA Mystery bolts MG 2
P Mystery Lexus?? Other Cars 10
T New Generator Mystery Austin Healey 5
B MGA Mystery MGA chassis part MG 3
K TR2/3/3A Mystery stall and no start? Triumph 7
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
AN6-TX Application of Marvel Mystery Oil Spridgets 8
J TR2/3/3A Mystery Wood Triumph 7
K Mystery badge bar Other Cars 4
P Mystery Car Other Cars 11
Y MGB A bellhousing mystery.... MG 3
P Mystery leftover BJ7 Pieces Austin Healey 18
warwick-steve Mystery Rattle Austin Healey 21
K Off Topic Mystery Windshield Brackets or ?? Triumph 6
warwick-steve Misfire mystery Austin Healey 28
ckeithjordan TR2/3/3A TR Mystery Thingy Triumph 13
S Marvel Mystery Oil Spridgets 7
D mystery Friday... Austin Healey 5
D mystery of the day... pedal block? Austin Healey 5
HighAltitudeTR3 TR2/3/3A Mystery Bracket Triumph 23
D TR4/4A water pump mystery hole Triumph 6
P TR6 Purple/Red wires & mystery bulbs Triumph 17
T TR2/3/3A Another Mystery Part Triumph 8
R TR2/3/3A Mystery part? Triumph 10
T 100-6 LHD/RHD mystery Austin Healey 7
