    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
my water gauge stopped working
Most likely, it sprung a leak. You have three options
1) Buy a replacement unit.
b. have yours repaired professionally
III: attempt a homebrew patch job that someone will supply a link to soon.
I went the ebay route for my replacement. As long as you get it cheap, you have nothing to lose. Just be sure to ask the seller to stick the bulb in boiling water and tell you how far it moves, before you bid! If it moves on beyond 'N' at 212 degrees, it's close enuf to tell you what you need to know.
Editor_Reid Water Temp Gauge Austin Healey 5
RickPA Water temp gauge reads low Austin Healey 6
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
M water temp gauge Spridgets 7
P Bugeye Water/Oil Combo. Gauge? Spridgets 4
P Bugeye oil/water gauge? Spridgets 6
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
J Oil/Water Gauge Austin Healey 5
BOBBYR Water Temp Gauge Austin Healey 5
memphis Oil / Water Gauge Line and the 3 loops? Austin Healey 23
luke44 TR2/3/3A TR3 Water Temp Gauge Core Triumph 14
bighealeysource Removing water/oil gauge - HELP Austin Healey 15
G Broken water temp gauge Austin Healey 14
pjsmetana Mechanical Sunpro Oil/Water Temp Gauge Triumph 5
R mech. water temp gauge repair? have you tried this Spridgets 4
19_again connection at water temp gauge MG 7
longbridgehealey smith oil/water gauge Austin Healey 7
AUSMHLY Oil/water gauge - anyone taked the front off? Austin Healey 1
Bruce_B Oil/ water gauge removal from 59 BE Spridgets 6
T Repairing a dual water temp / oil gauge Spridgets 1
MGTF1250Dave Water Temperature Gauge Triumph 2
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
D Water Valve Connection Austin Healey 4
T TR2/3/3A Moss uprated water pump Triumph 6
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
P MGB Zenith water choke gasket needed MG 4
T TR2/3/3A Water pumps/head cooling Triumph 22
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Aussiea40 A40 water pump British Motor Corp 7
A MGB Stuck water temperature sensor MG 26
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
shadowfever Water temp Spridgets 9
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
Lin Heater water valve question Spridgets 2
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Water pump Austin Healey 5
Patrick67BJ8 Water filters Austin Healey 16
George Zeck Water Pump ? Spridgets 5
