Wanted MK2 - Please, help needed
H
herger
Member
Sorry, Larry, just a question:
is it "normal" that the plate has the "DN" suffix (the car *has* the overdrive), but there is NO "DN" punched on the chassis??
Thanks again and regards!
H
LarryK
The chassis # will not have the extra #s or letters of the plate. Plate was added after the body, engine, trans, od , and axles were installed. The DN might be a designation of overdrive or country delivered from. I have a plate from France with the word France on it, so I will have to look up when I have time.
H
herger
Member
Thanks truly much!
LarryK
DN designates Overdrive option. Only option available besides automatic transmission. Sunroof was dealer installed option.
H
herger
Member
Sorry, Larry, one more question (You are always very very kind):
entering the car, there was a very slight stale smell. I thought it might be the ceiling (headliner).
Is there a way to clean it, without substituting it? Could I use some hot-water upholstery washer or is it dangerous to use hot water?
Do You recommend some cleaner and microfibre towel? Can I rub it or will I ruin the headliner, tearing it apart?
Thanks and regards!
H
LarryK
Put a pan of white vinegar on the floorboard or a bag of charcoal briguets (open bag ), close doors and windows a leave alone for a few days. Or, if in a garage, open windows. Will go away with time in the air. Might even leave in driveway in the sun with windows down. Use leather creme cleaners and renewers on leather only.
H
herger
Member
Fantastic, thanks!!!
I'll keep You posted!
H
H
herger
Member
Dear Larry, dear All,
good afternoon.
Next week I'll go to have a ride on the MK2 and, in case everything is ok, purchase it.
I am really excited!
I would like to do 2 things as soon as I get the Jag:
1) A full service to the Car: oil, air filter, oil filter, spark plugs. Do You recommend anything anything else?
Please: I need to have the specs of the best oil, oil filter and air filter, as well as the spark plugs.
Can You, please, point me to the best brands for the MK2 and (in case) identification numbers? Where can I buy them?
2) The wire wheels will need a bit of maintenance to come back to shine: what can I use? The rust on the wires is very low, but there is some
brittlement on the spinner. Is there a brush or something that I could use on a drill? Some sort of drill brush with some spray/cream product?
Thanks in advance and best regards!!
Herger
LarryK
Follow reccomended oils and fluids on data plate on fender. I have no clue what you have in your area for what you want.
H
herger
Member
Thanks.
And for the brittlement on the spinner and the (little) rust on the wire wheels? What would You recommend?
LarryK
Non-abrasive cleaner and polish using toothbrush and wiping clean wth soft cloth.
H
herger
Member
good afternoon.
TOMORROW, I’ll go to test the Jag, I’m so so excited!!!
I am planning to do this, please, let me know Your suggestions:
1) look carefully below the car and inside the hood;
2) start the engine and let it run for 20-30 minutes in idle, and check leakages and so on;
3) go for a 45-60 minute ride and then check back leakages from basement, differential, radiator and brakes.
During the run, I plan to carefully listen to potential ticking noise from engine/transmission and check the steering wheel.
Do You have any other suggestion on what to check?
THANKS in advance and my very best regards!!
Herger
LarryK
Things you said.
LarryK
Any update?
H
herger
Member
Any update?
Thanks, Larry!
Sorry for the late reply.
Not yet: we have postponed the final test due to (terribly) bad weather.
Now, I am out for work, and I’ll be back to Rome at the end of Feb.
Probably, we’ll meet on Saturday, March 4th.
Of course, I’ll keep You posted!!
Thanks truly much, Larry, my very best regards!!
herger
H
herger
Member
Any update?
Hi, Larry, hi All.
I have taken a break: in Rome in this period, only >Euro3 cars can be used….
They installed cameras to fine also classic cars…
Maybe they will change this local law, due to the large amount of protests, but I plan to reconsider the purchase after summer….
H 1956 Ford Zephyr mk2 - any advice please Other British Cars 1
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
H MK2 lover, but... what about an E type? Jaguar 5
Sopwith_Camel linkage jag mk2 Jaguar 1
Bristol401 For Sale Jaguar Mk2 Jaguar Classifieds 2
T Spitfire MK2 Generator Triumph 3
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
T Spitfire 67 MK2 Wiring Triumph 12
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
C Wanted triumph spitfire mk2-3 drivers seat bucket Triumph Classifieds 0
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
T MK2 vs 420 values Jaguar 20
A Austin Cambridge MK2 Other British Cars 2
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
I 1961&62 Mk2 sprite roofs Spridgets 1
I 61&62 mk2 roofs Austin Healey 2
D MK2 fuel system Jaguar 1
D MK2 rear springs Jaguar 3
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
LarryK Found MK2 parts in cavern. Jaguar 3
blurooster MK2 for wife Jaguar 21
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
M Healey Mk2 with Colored stock steering Wheel Austin Healey 3
D MK2 front motor mounts Jaguar 0
RickB Poor little MK2 Sprite - Seattle Craigslist 'Sebring bonnet' Spridgets 24
Sopwith_Camel mk2 parts left over Jaguar 4
S My dads 1962 Mk2 Austin Healy finally seeing light since 1981. Austin Healey 4
H MK2 Brake problems Jaguar 2
Lin Reinstalling rear springs and axle in 64 MK2 Jaguar 1
Lin Check Valve for Reservac Tank - MK2 Jaguar 3
M Spitfire Spitfire MK2 calipers Triumph 4
B going to look at a 61 mk2 Jaguar 5
AN5Sprite Jag Mk2..Deal or No Deal? Jaguar 12
D MK2 brake puzzlement Jaguar 15
C What are the differences in Midget MK2 and MK3 top Spridgets 6
L Spitfire 1965 Triumph Spitfire MK2 Triumph 4
longbridgehealey top bow mk 1 and mk2 sprite Spridgets 4
6 '65 MK2...typical "whats it worth ? " post Jaguar 4
J Brakes for a Mk2 Ford Cortina Other British Cars 4
D MK2 idler arm Jaguar 6
K Door Strikers and Latches MK2 Triumph 3
D MK2 rear axle "Bump Steer" Jaguar 4
D MK2 upper radiator hose question Jaguar 3
D MK2 wiper motor Jaguar 4
D MK2 sandwich mounts Jaguar 3
D MK2 console armrest Jaguar 3
