midget 1500 exhaust system
jim79
I have a 79 midget 1500 and the exhaust system has got numerous holes in it. My question is; what is a good exhaust system for these cars? The original on my car looks like someone took a swingset apart and made a exhaust sytem out of the bars! Moss motors says the monza system only goes 19 inches forward of their muffler and then you use the original pipe up to the engine.? Why put a "free flow" muffler on a stock pipe that loses 25 percent of the pipe in areas with a bend?
I'm leaning towards letting someone custom pipe it but wondered what everyone's experiences were with different exhaust systems out there?
Bugeye58
I've always been pleased with the Falcon stainless systems on my "A" series cars. A bit pricey for the 1500 cars, though.
Jeff
i made my own after being rather dissapointed with the choices out there. i purchased a Harbor Frieght pipe bender, 10ft of 2 in mild steel tubing, and a bag of sand, and a cherry bomb turbo 2 muffler. Fill pipe with sand, bend gently (the sand prevents kinking) There are not any really tight bends and i just copied the old system that i had on the ground. doesnt sound to bad either...
mark
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
c5racer Spitfire 1500 Spit exhaust manifold fit a 1500 midget? Triumph 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
DanLewis 1500 cc MG Midget Radiator in a Bugeye??? Spridgets 5
J 1500 mg midget fuel issue Spridgets 2
J 1500 midget master cylinder Spridgets 10
T ZS Question for 76 1500 midget Spridgets 33
T 76 midget 1500 oil pressure lines? Spridgets 15
frankenstang57 Educate me on the Midget 1500 MG 4
R Overdrive/5 speed options for 1500 Midget? Spridgets 21
P how to replace rear main seal in 1500 midget Spridgets 2
R pcv valve for 1500 midget? Spridgets 18
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
T 76 midget 1500 engine crud Spridgets 4
RickB Seat recovering, 1500 Midget Spridgets 18
R 1500 midget clutch inspection? Spridgets 3
R oil feed kit for 1500 midget? negatives in this? Spridgets 5
Rhodyspit75 Spitfire Midget carbs and manifold on 1500 Spit Triumph 6
D Vacuum unit for 1500 Midget Spridgets 7
P holes in 76 midget 1500 front bumper Spridgets 6
R compression test procedure on 1500 midget Spridgets 5
G 79 midget 1500 clutch? Spridgets 5
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
bcbug Midget 1500 Hose Connections Spridgets 9
RickB Midget 1500 dual circuit Master Cylinder troubles Spridgets 7
7 79 midget 1500 Emission Removal Spridgets 3
G 79 mg midget 1500 wiring Spridgets 7
bcbug 1500 midget carb replacement Spridgets 38
A 1300 cam bearings in Midget 1500 Spridgets 3
M 78 1500 Midget Tire Sizes Spridgets 1
J Midget 1500 electronic ignition? Spridgets 10
S 1500 Midget air intake Spridgets 1
S 77 Midget 1500 gearbox Spridgets 4
boxfullofyertoys Midget 1500 idle problem MG 0
boxfullofyertoys Midget 1500 idle problem Spridgets 10
