MGB Mgb turn signals
Carlbanan56
Hi, I have some questions about the turn signals on my mgb 1975. Neither my turn signals nor my hazard lights seem to be working. I have only tried the signals with the engine turned off due to the extreme cold here in Sweden right now, don't know if that has an impact. I am a bit clueless about where to start. Most of what I have read online seems to be going into a problem where the turn signal does not work but the hazard lights do. The turn lever is also very hard to maneuver. Where should I start?
JPSmit
start by checking your ground wires. They are always black and most of the time that is the problem. There is an issue with the hazard lights/signals but, there are other things to check first
do you have a manual with a wiring diagram?
YakkoWarner
JP is right - the grounds are always a bit suspect so a logical 1st place to check. I even went so far as to do a high temp solder of a ground wire onto every lamp fixture - solid grounds clean up most of the infamous Lucas electrical gremlins.
Using the hazard lights should work regardless of whether the engine is running or even if the key is in the car. Turn signals should work with the key on, even with the engine not running.
Grantura_MKI
You need a wiring schematic. This is a more complex system once the emergency flashers where added.
For starters, there are two flasher units fitted and usually an in-line fuse fitted to the power lead of the emergency flashers.
Mickey Richaud
Carlbanan56
Carlbanan56
I will check all the grounds. I should have mentioned it earlier but when I got the car it had not moved for 25 years. During this time the grounds could gone bad. Which ground should I check? Maby a dum qustions but where do I find them?
Mickey Richaud
No dumb questions here!
Start at the lamps. Should be a ~cluster~ of black wires connected to the body, front and rear. The rear one, I believe, is along the back of the boot (trunk). Don't remember exactly where the front one is, but have a look near the harness where the wires come out of the sheath and follow the black ones. Disassemble the connections and clean each ring terminal, along with the area of the body where it is attached. Put it all back together and after screwing it back in, smear on some dielectric grease to protect it.
And while you're at it, go ahead and disconnect all the positive wires' bullet connectors and clean them up as well.
Hope this helps!
AUTOMOLOGIST744
I had the same issue except for the stiff turn lever. mine was on my MGB the flasher unit was bad. everything worked perfectly after replacing the unit. it was a quick fix. But as the other responders here have advised a car sitting that long should have the wiring gone over top to bottom...and yes especially the grounds. rodents love to eat wiring. and depending on where this car was stored they may have had a field day. be safe and not sorry. bad wiring can be a fire waiting to happen. good luck. btw a little electrical lube spray may ease the joint of your turn lever
YakkoWarner
My lever fell apart when I tried to move it - had to get a replacement from Moss which seems to work just fine. I had the added trickery of dealing with installing 1970 equipment into a 1973 body/harness, so the ground connection for the in-lever horn button didn't exist in my wiring harness.
If you buy a new one, make sure you get the right one unless you're doing something foolish like me....
Alski99
For my ‘77 B, when the turn signals and hazard lights were not working, it turned out that the hazard switch on the dash was bad. On my ‘77, the turn signal flasher and the hazard flasher are both wired to the back of the dash hazard switch. Because the switch was bad, neither was working. Replacing the switch on the dash worked for me. It’s probably best to check grounds and other connections first, but a new switch is pretty inexpensive.
Al
‘77 MGB
Brooklands Green
BobHaskell
I had better luck taking the switch apart and cleaning it. The replacement switch I bought had an issue with the spade connectors on either side of the switch. They would pull out of the switch when I attempted to remove either wire. (dash lights)
Alski99
I should probably have done the same. Aftermarket parts are almost always not as good as original. Luckily, the new switch that I purchased worked well.
YakkoWarner
I had a hazard switch from Moss fall apart the first time I tried to connect the wires to it - fortunately they were real good about getting me a no-cost replacement since it was only a few weeks old. My original 40+ year old one disintegrated in my hands - the plastic was just so brittle.
JPSmit
I have not had a ton of luck (IE No luck) repairing the old hazard switch and had to buy a new one, but, in this case we have many easier options to try before we get to the hazard switch (I hope)
Carlbanan56
Carlbanan56
I just got the turn signals up and running. A new flasher and cleaning the points on the turn lever solved the problem. Unfourtenetly the hazard lights don't work so that will be the next fix.
Joe Reed
Sometimes the hazards don't work because a bit of corrosion builds up on the contacts over time since the switch is so seldom used. If you're lucky turning the switch on and off a number of times will clear that and they'll work.
E MGB Turn signals 65 mgb MG 4
W MGB Turn signals on 78 MGB MG 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
R MGB Turn signal help 67 MGB MG 2
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
B MGB Too late to turn back now. 67 MGB MG 147
kyreb1862 MGB MGB Turn Signal Improvements MG 0
QuickSilver MGB 77 MGB - Turn Signal, Brake Lamp and Hazard Issues MG 22
M MGB 78 MGB Turn Signal MG 15
Scott_Hower MGB MGB - Left turn signal wont flash, brake light dim MG 16
P MGB 77 MGB Turn light dashboard indicator MG 9
1 MGB My new 1977 MGB? cant turn distributor MG 3
Carlbanan56 MGB MGB valve seals MG 1
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
AngliaGT ANOTHER TR6,& an MGB Spotted 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
