Aussie Chris
I have a 1974 Mgb and trying to remove dual water temp and oil pressure gauge. I removed the nut holding the sensor just under the thermostat housing but the unit will not come out and I don’t want to force in case breaking the tubing going to the gauge. So far have move it a bit sprayed with wd40 but no go would still having the system full of fluid create suction to stop it coming out no water has come past the sensor .
Also would taking out the thermostat give me access to the sensor ? The engine it self has just been rebuilt and working fine initially I had issues with blowing welsh plugs but this was due to wrong pressure radiator cap it took three plugs to find this out .
If anybody could give me some idea how to tackle this issue it would be much appreciated
Regards
Aussie Chris
Regards
Aussie Chris
