MGB MGB oil consumption
Carlbanan56
Guys, I have posted quite a few times here about my problems with my granddad's 1975 MGB. I acquired the car 2 years ago, and it had been stationary since 1995. Over these two years, I have checked and replaced various parts to get the car ready for what is known as "Besiktning" in Swedish—a mandatory car inspection every 2 years. Once a car turns 50 years old and has passed inspection in the last two years, it's exempt from further inspections. Three days ago, the MG passed the inspection and became road-legal. As you can imagine, I've been enjoying driving the car that I've been working on for 2 years over the past few days. It's been super enjoyable!
As with every previous post I've made, there's always a problem, and this one might not be a simple fix... Yesterday, I took the car for its longest ride yet, about 25 km. Before setting off, I checked the oil, which was right above the minimum mark. This should have raised an alarm because the last time I checked, it was right under the maximum mark. This morning, as I was planning to take the car for another drive, I wanted to ensure the engine had enough oil... but it didn't. Check the picture; the oil level is significantly below the minimum mark.
I could think of three causes for this. The first one is oil leaking out of the oil plug. I checked the plug, and it was dry. The second and third causes both involve the engine consuming oil, which would make sense given how poorly the engine would run. It would start and idle great, but driving was fine only as long as you didn't press the accelerator past a certain point. Initially, I thought this sounded like the engine was getting too much gas, but now I suspect it might be getting too much oil... I'm guessing either the rings or the head gasket are faulty.
If the head gasket is faulty, it should be a relatively simple fix—installing a new one, right? Of course, it will be a significant job, but still relatively straightforward. I'm much more concerned if one or more of the rings are faulty. Then I'll be forced to dismantle the whole engine. Hoping you guys have some insight.
Young and inexperienced
BobHaskell
On a drive do you notice any smoke out the exhaust, on start up, during acceleration or decels? Any large oil spots on the driveway/garage floor? A compression test will give you a idea if the issue is with the head gasket or the rings. Another issue may be the valve stem seals have failed allowing oil to get sucked into the cylinders.
A leakdown test would be another option, but that requires the leakdown gages and a source of compressed air.
Carlbanan56
Carlbanan56
No smoke when warm. But I have noticed some oil coming out of the exhaust and some oil on the spark plugs. I did not know about the valve seals, may as well be the issu. I will check the compression to narrow down the faults.
Tank you😄
JPSmit
I would also not rush to take things apart. If the car has been sitting for over 25 years there is a good chance things just need to run in a bit to seal better. I might keep an eye on the oil and run it for a few hundred miles before you do anything too drastic. I would also change the oil before too long.
Carlbanan56
Carlbanan56
I did a compresion test to day and 3 of my cylinders hade around 150 psi of pressure while one was a bit lower at around 135 psi.
Mickey Richaud
Those are good numbers. If accurate, sounds like the rings are good. Valve stem seals would be suspect...
J MGB MGB Oil Consumption MG 57
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
P MGB 1980 MGB carb and oil questions MG 3
E MGB SU CARB OIL 1965 mgb MG 3
K General Tech Why did MGB's come with oil coolers but Triumph's didn't? Triumph 17
PAUL161 MGB MGB Transmission Oil Capacity ? MG 2
J MGB Length of MGB oil stick for 1971 MG 1
Lynn Kirkpatrick MGB MGB High Oil Pressure MG 6
Sebring222 MGB MGB Oil Cooler Thermostat MG 4
kyreb1862 MGB 77 MGB Oil Leak MG 3
R6MGS MGB MGB tranny oil? MG 31
eschneider MGB mgb trans oil drip into bellhousing MG 8
W MGB 78 MGB oil pressure MG 3
martyc MGB MGB Transmission Oil -- with Tasty Metal Shavings MG 2
A MGB MGB 1977 oil pressure problem MG 31
A MGB 1977 MGB oil pressure problem MG 0
kyreb1862 MGB Oil Filter Problem 77 MGB MG 10
F MGB Pinion Oil Seal Replacement - MGB Tube Type Axel MG 8
kyreb1862 MGB MGB Oil Filter---Which one is best MG 14
Mickey Richaud MGB Oil to Head - MGB MG 5
W MGB MGB GEAR BOX OIL. MG 7
R MGB Oil cooler on '78 MGB MG 6
mopease MGB oil leak on my '73 mgb MG 2
Obtong MGB Stuck on my MGB: Oil Filter MG 29
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
