LUCAS 17L Batteries for Healey 100s
Rmoment
Reproductions of the LUCAS 17L 6-volt batteries used in Healey 100s are now available again, after a 4-year absence. Jim Irwin, the new owner of Jim’s Battery Manufacturing Co. (previously the Antique Battery Mfg. Co.), is now taking orders for this size battery. It has a 6-volt maintenance-free battery (you never need to add water or acid) contained inside the reproduction LUCAS 17L case that had been available since the 1990s. It has the LUCAS fill caps (which are now just for show), but if you remove the end ones you’ll see cable connections to the internal battery. Holes at the ends of the top are for original mounting hold-down hardware.
Contact information for ordering is:
https://jimsbatterymfg.com/
When calling, I suggest you select option #3 from the phone menu.
Roger
That is very good news, Roger, thanks for posting. I tried to order a couple 17Ls from AAB a while ago but they weren't responsive; ended up with some 17Hs which, as you probably know, just barely fit under the cover. Any idea what the CCA for these is?
R
Rmoment
I don't know that number. However, Jim told me that you can use a maintenance charger with them (not to exceed 8v on a 6v battery; but you can use a 12v charger with the two in series in a Healey 100). I use a Battery Miinder -- https://www.batteryminders.com/12-volt-maintenance-charger-desfulator-1500. This will maintain the voltage, but if you store for over a month without driving you should turn on the headlights for 10 minutes or so (engine off) to draw down the battery and then reconnect to the charger. This periodic cycling will keep the amp-hour capacity up, which would deteriorate if just left on the maintenance charger without cycling. He said the batteries should be good for 8 years, or so, with this technique. If you drive the car regularly you don't need to go through this routine.
It also is possible to use the 17H batteries, but you need to just be careful that they are held down using proper rods -- original mounting hardware -- and have the Armacord pad on the underside of the battery door. With this installation, there should be a gap of about 3/8" between the "-" terminal of the RH battery and the underside of the Armacord, which is plenty to avoid any chance of shorting. Back in the '70s I used Interstate 17H batteries for years without ever having a short.
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
MGTF1250Dave T-Series Lucas Generator MG 1
T Lucas Flasher Unit Austin Healey 5
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
B TR6 Swapped Lucas to GM alternator Triumph 9
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
Lin Lucas coil question Austin Healey 8
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Navigation Questions 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
F T-Series Lucas m133 headlamp? MG 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
S Intermotor or Lucas Sport Coil ? Austin Healey 14
C General Tech Lucas Fog Lamps Triumph 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
C TR6 More fun with Lucas Triumph 5
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
Michael Oritt Lucas 576 lights Austin Healey 4
J MGC Lucas alternator/regulator MG 3
Rob Glasgow Weird Lucas Headlight Austin Healey 7
CJD General Tech Boeing using Lucas parts? Triumph 7
D Wanted lucas wt618 Triumph Classifieds 0
Basil SOLD!! Lucas Spot and Fog lamps Jaguar Classifieds 1
H Lucas Prince of darkness Austin Healey 4
NutmegCT Lucas 432 bulb Restoration & Tools 6
T Lucas HF 1748 horn parts Austin Healey 5
T TR5/TR250 Question on Lucas Hazard relay Triumph 14
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
Patrick67BJ8 Lucas SLR Driving Lights installation Austin Healey 26
M TR2/3/3A Moss Lucas elektrik alternator install? Triumph 5
A TR4/4A Lucas parts Triumph 7
TulsaFred Moss Lucas Control Box/voltage regulator Spridgets 4
