lube starter gears?
nbailey
Member
The starter on my 4a was sticking, so I have pulled it and cleaned the starter gears. The Haynes manual says to leave the bendix portion dry, but a mechanic friend says I should oil it. any opinions?
I agree with Andy...no oil or grease, as it will only attract dirt and grit. Having been in the electrical rebuilding business for the last 35 years, I have never seen an OE manufacturer use any type of lubricant on their starter gears.
+1 again for dry or powdered graphite (or moly). Most hobby shops have the powdered graphite.
Oil is the reason it was sticking in the first place.... Unless you enjoy pulling the starter don't oil it. If it makes you feel better put some sort of dry lube on.
+1 on dry lube. I use spray "moly"
LD-Ordie Series II gear lube question Rover / Land Rover 3
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
Michael Oritt Steering box lube Austin Healey 22
S Ignition advance weights - how to lube? Austin Healey 5
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
D TR2/3/3A lube equivalents Triumph 3
JFS TR2/3/3A Wiper Cable Lube Triumph 5
S TR2/3/3A lube for upper A bushings Triumph 2
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
N Best lube for a Datsun gearbox?? Spridgets 6
K TR2/3/3A Penrite semi fluid steering box lube? Triumph 14
R TR2/3/3A Oil gun for 'Propeller shaft" lube Triumph 9
D TR2/3/3A Universal Joint Lube Question Triumph 8
tomshobby General TR making it easy to lube door hinges Triumph 0
KVH General Tech Assembly Lube Triumph 2
KVH General Tech Assembly Lube and Zinc and New Cam--TR4A Triumph 7
3798j LocknLube Restoration & Tools 0
S TR6 Trunnion lube Triumph 6
Griz New Engine Pre-lube BJ7 Austin Healey 13
Rut Steering column lube Spridgets 2
RickB 78 Midget steering rack lube? Spridgets 4
D Grease nipples to lube the back of the rear spring, BT7 Austin Healey 7
J Wedge TR 7 Differential Lube Triumph 3
6 Dif lube? Spridgets 8
KVH TR4/4A TR4A Differential Lube Triumph 5
D Lube in OD gearbox MG 15
DNK What Lube to use Triumph 0
sjuengst Gear lube leaking from hub Austin Healey 8
RJS Correct Lube for Steering Box/Rack? Triumph 1
71tr How to pump oil through a lube gun? Triumph 4
Sopwith_Camel lube me! Spridgets 20
glemon Polyurethane Bush Lube Triumph 8
Sopwith_Camel brake lube Spridgets 5
T Correct grease / lube for Poly bushings Triumph 10
sparkydave Steering rack lube Spridgets 19
Brosky Tach cable lube Triumph 4
tomshobby A way to lube the clutch pedal pivot. Triumph 1
DNK Brake Lube Triumph 5
Bruce_B Datsun 5-speed Gear lube recommendations needed Spridgets 9
71tr Clutch Lube Triumph 8
D Pre-Lube Systems Triumph 11
J Spitfire Differential gear lube level 78 Spitfire Triumph 5
YankeeTR Quality Lube Products... Triumph 1
tahoe healey lube chart Austin Healey 6
71tr clutch component lube Triumph 0
BIBBER TRANSMISSION LUBE CAPACITY Spridgets 3
fmichaels tranny lube Spridgets 16
G How do I separate my drive shaft to lube splines Triumph 4
Lin Front suspension assembly lube Austin Healey 1
A Lube for poly bushings ?? Triumph 5
