Linkage for twin SUs
eejay56
Does anyone have a good picture showing the linkage and fuel lines for the twin SU setup? I'd like to replace the Weber on my Spit. Rimmer Bros website has the exploded drawing showing all the pieces but I'd like to see the real deal. Here is what I've got.
IanF
I'll try to get a picture posted, but in the meantime I'll describe how I set them up. Not quite OE, but it seems to be working well enough.
I ran the fuel line in steel from the fuel pump, behind the engine, up across the top of the cable bracket and then down to the front carb inlet (with short hose connecting the pump and carb). I made supports at the cable bracket and at one of the bellhousing nuts. The carb to carb run was also down with bent steel tubing with short connecting hose. The OE routing is right across the front of the filters, which seemed odd to me (especially given the fancy filters Robyn got) so I ran them under the filters.
For the linkage, I routed the cable across the engine in the same manner as the OE Z-S (not sure if the Weber cable can be modified) using the stop bracket from the Z-S manifold. Take a look at the linkage lever between the carbs - the part the cable attaches to. The linkage on the carbs when we got them was too long to allow the cable to pull the throttle plates much past 1/2 open. I ended up digging up a linkage set at Carlisle that moved more for a given pull of cable.
Todd78d Bugeye choke linkage Spridgets 5
Todd78d Choke Linkage Photo Austin Healey 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Sopwith_Camel linkage jag mk2 Jaguar 1
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
Michael Oritt Clutch Linkage Austin Healey 19
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
M Choke Linkage Austin Healey 3
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
AngliaGT MGB-GT SU Carburator Linkage - MG 9
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 32
C Jammed Throttle Linkage Austin Healey 3
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
Sarastro TR4/4A Stromberg linkage question Triumph 4
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
doc50 73 Midget Carb linkage confusion Spridgets 5
K TR2/3/3A SU horizontal carb linkage rod? Triumph 3
D BT7 tri-carb linkage set up Austin Healey 23
J Wanted WANTED; XK150 Triple Carb linkage Jaguar Classifieds 0
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
K TR2/3/3A Sloppy SU linkage and DIY bellcrank repair? Triumph 6
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Rut TR4/4A SU throttle linkage and brackets Triumph 5
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
S TR2/3/3A Linkage issue? Car stalls when braking hard Triumph 17
MY66AH Throttle Linkage Spridgets 9
H T-Series Need carb linkage info for my TD MG 1
K TR2/3/3A Auxillary carb linkage return spring? Triumph 2
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
F Gas pedal linkage BJ8 Austin Healey 6
S TR4/4A choke linkage Triumph 2
mgedit TR2/3/3A Link Rod Lengths Accelerator Linkage Triumph 2
GTP1960 TR2/3/3A Rear shock linkage orientation? Triumph 2
B Carb Linkage Issue [3000 MkI] Austin Healey 6
GTP1960 TR2/3/3A Removing the silentbloc rubber pieces. From the steering linkage bush Triumph 7
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
K TR2/3/3A Su carb rod linkage bell crank stud? Triumph 6
T TR6 TR6 - alternative linkage design? Triumph 4
sundown TR6 carb linkage Triumph 7
J TR2/3/3A Throttle cable instead of the linkage?? Triumph 1
newmexTR3 TR2/3/3A TR3 Throttle linkage pics needed Triumph 19
T sourcing linkage ball/sockets Austin Healey 13
H TR4/4A 4A Throttle linkage for HS6 SU Triumph 2
F BN1/BN2 Clutch linkage Austin Healey 4
K TR4/4A TR4A SU's replacing Strombergs....Linkage issues? Triumph 10
