Gas pedal linkage BJ8
fordtrucks4ever
Last year I finally got around to changing the freeze plugs. It took forever to find brass ones, but you guys here got me going. Since having the Healey running is not a priority at the moment, I didnt get around to bolting everything back together until last month. The gas pedal linkage doesnt seem to have the right amount of travel and I am not sure if I connected it back right or not. I dont know if you can see much from the pic. It seems like I need more length on the tie rod from pedal to the bellcrank. Unless I managed to get something totally backwards. What is odd I didnt remove the tierods from body, just disconnected them at one end, so I am at a loss to figuring out whats up. It was fresh in my head last year, but I have slept since then. The arm from gas pedal is already too far past center to have any travel to open carbs. I did replace the rubber bushing on firewall, but that would not change the length enough for what it needs.
attachment.php
steveg
The Bentley manual has a scale drawing of the linkage on page 55 with dimensions on the following page. Section A.37.
In your picture, the control arm shown should be just off vertical not quite in the 1 o'clock position.
Whats the height of the pedal in the car it should be equal to the brake
Theoretically, the gas pedal should be the height of the brake pedal when the brakes are applied to facilitate heel-and-toe downshifts. My BJ8 is close to that, but you really have to contort your right foot to heel-and-toe, in 'normal' driving it's not worth the trouble.
IIRC, the shop manual has an extensive write-up, complete with excellent drawings and measurements, for adjusting the gas pedal (it's buried under tools and spare parts in my boot, and I'm too lazy to extract it).
BigGreen
Hi, Fellow Metallic Golden Beige BJ8 owner
These are the pages from the Bentley
Hope they help you
Patrick67BJ8
attachment.php
Terry, Bring your Healey to the next North Texas Austin Healey Club's Tech Session next Saturday and you'll get help there. The second Saturday of every month(with exceptions for Holidays). Donuts & Coffee at every Tech Session!
F
fordtrucks4ever
Thank you BigGreen. That is exactly what I needed. Thanks to everyone for their input. Greatly appreciated! Patrick, I have been trying for nearly 10 years to attempt one of the work days. Maybe it will happen in my lifetime. Something always seems to come up. A few times I actually tried until the sky opened up and changed my mind.
T Pictures of Bugeye gas pedal and linkage Spridgets 2
R TR2/3/3A Gas pedal pad for TR-2 Triumph 3
BierRunner TR6 TR6 Gas Pedal Triumph 4
J For Sale Triumph Tr 2/3 Gas Pedal Triumph Classifieds 1
D Gas Pedal Pad Jaguar 7
S TR2/3/3A gas pedal rod Triumph 2
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
Rut 1500 gas pedal for sale Spridgets 7
I TR2/3/3A Gas Pedal - Rubber Cover? Triumph 6
L Hanging gas pedal in BE Spridgets 22
S TR2/3/3A Tr3 Gas pedal height from floor Triumph 15
jjbunn E-Type gas pedal travel Jaguar 11
J Spitfire Spitfire MK1 or 2 gas pedal bushings Triumph 11
bcbug Bugeye gas pedal Spridgets 6
S Gas Pedal pad for 76 Midget Spridgets 3
jvandyke gas pedal bolts? Spridgets 5
J Mg Midget 1500 gas pedal broke Spridgets 5
RickB Gas pedal sticking - maybe the cable? Spridgets 15
S TR2/3/3A Tr3 gas pedal Triumph 3
AUSMHLY Gas pedal play Austin Healey 16
B gas, Brake, Clutch Pedal covers? Spridgets 8
bobh TR6 TR6 Gas Pedal Shaft Bushing Install Triumph 16
Radford The Paddy Hopkirk gas pedal - is it a good idea MG 7
S TR2/3/3A Tr3 gas pedal shaft socket Triumph 7
L Gas Cap Recommendation Austin Healey 1
Celtic 77 MGB LeMans Gas filler MG 10
mctriumph General TR NEVER start a car with stale gas Triumph 0
TomMull GT6 Gas Tank Outlet Triumph 0
B TR6 Gas on spark plugs Triumph 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
Celtic 77 MGB Pessimistic Gas gague MG 10
B gas leak underneath the carburetor Restoration & Tools 2
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
LAW75 Concours: Original Gas Hose Austin Healey 12
LAW75 Gas Odor Elimination Austin Healey 3
B TR4/4A GAS TANK FELT Triumph 14
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
edkap2002 TR6 gas smell Triumph 8
B Damaged threads in the gas tank Austin Healey 7
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR4/4A Gas Tank color? Triumph 4
B BE vs. Later Model Gas tanks Spridgets 2
