Keeping the throttle linkage shiny
tdskip
Hi guys - cleaning up the HS6 conversion bits from Marv (thanks Marv!) and got the throttle linkage shiny again, but how to keep them shiny? What say you?
Shot of clear enamel?
I put all mine in a box and got them cleaned and zinc plated at J&E Specialty, 519 Central Avenue, Dover, NH 03820-3420, (603) 742-6357.
Tom
As I recall it was $40 a year or so ago. (I had it done with some chrome) I believe the Factory plated some stuff with zinc and other stuff with cadmium. Some of it was unfinished too, as far as I can tell.
Tom
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
wangdango Keeping the heat out? Austin Healey 11
J What's the Secret- Keeping New Aluminun Shut Face Finishers Looking New? Austin Healey 7
M Looking for opinion on keeping original parts for my modified Healey Austin Healey 8
R Keeping Cool in Florida Austin Healey 1
D Keeping Bondo cool - Texas style Spridgets 1
M Generator not keeping up? Triumph 10
K Keeping a Flywheel from rusting.... Triumph 13
J Electric Fans and Keeping Things Balanced Triumph 3
drambuie KEEPING YOUR HEALEY RUNNING COOL....... Austin Healey 23
E Keeping the rodents at bay Restoration & Tools 5
N Keeping cooool !! Spridgets 24
Newkie MGB keeping mice away from my winter stored MGB MG 11
John_Mc Denial not keeping rust away. Triumph 13
SCguy TR4/4A Keeping your TR4 cool? Triumph 13
J keeping the heat out Austin Healey 10
kodanja Keeping up with Traffic Triumph 51
ronzet Keeping the brake and fuel lines nice and bright Austin Healey 3
A keeping choke from sliding back in Austin Healey 28
B Keeping doors closed Austin Healey 17
U Keeping Them On The Road Triumph 5
Bret Keeping busy: Cosmetics upgrades. MG 12
B Keeping my top on Austin Healey 6
G HD8 Throttle Shaft Austin Healey 2
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
S Overdrive Throttle Switch Austin Healey 4
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 34
Walter74 Throttle Cable Conversion Austin Healey 6
J Throttle Controls Identification Austin Healey 4
B RHD BJ8 Throttle Control Rods Austin Healey 9
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
C Jammed Throttle Linkage Austin Healey 3
R TR2/3/3A Throttle rod spring location Triumph 3
T BT7 throttle relay levers short and long Austin Healey 2
R TR2/3/3A Carb throttle return spring tension Triumph 2
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
D TR4/4A SU HS6 throttle spindle size Triumph 20
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
warwick-steve Throttle shaft bearing/bush on bulkhead Austin Healey 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
