TR6 Is there any such thing for a TR6 ?
Lou6t4gto
I'm re- doing a 1973 TR6, noticed the front Sway Bar is pretty anemic, are there any larger diameter sway bars available ? Also, are there any REAR Sway Bars available ??
TR3driver
Great Pumpkin - R.I.P
ADDCO offers both uprated front and rear bars. If you ask, I believe Richard Good (Goodparts) will bend custom bars in your choice of thickness.
Tybalt
Regarding the options presented so far, the ADDCO bars are OK. They provide a very noticeable improvement in body roll reduction at a reasonable price. The rear bar is essentially the bar that Kastner describes in the old Triumph Competition Preparation book. If you go with the ADDCO, don't bother going with their "adjustable" end links, it's a rather hokey set up.
Richard Good's bars are nicely done and offer adjustable link set ups that actually work although they do require disconnecting one link should you want to adjust the link. In addition the rear bar is set up so that you can also adjust the bar stiffness by the selection of different holes at the end of each arm, altering the effective arm length. Cost is higher than for the ADDCO stuff, but it's also a nicer set up. Both the ADDCO and the Good Parts rear bar will cost you a bit of ground clearance at the rear.
The Ratco rear bar requires either one of the Ratco frames or modification to the stock frame (get out your welder) and trailing to use a tube damper that will run through the middle of the spring. The anti-roll bar is mounted high along the structure that has the upper spring perches and the end links run down to the holes in the trailing arm where the original lever damper links would have mounted. The Ratco front bars (7/8" and 1" dia available) mount in the same manner as the stock TR6 front bar. Neither the rear or front Ratco bar are adjustable.
There is a fourth option from Revington TR that predates and is similar to the Ratco rear bar except that it is adjustable by means of a sliding block that can be positioned and then locked into place altering the effective arm length. It's another one of those "get out your welder" and prepare to modify the trailing arms propositions. Their 7/8" front bar is not adjustable IIRC and their other front bar is "a bit much" to use with their high mount rear bar in the calculations that I ran.
I have the Revington set up on the rear of my TR6 and the ADDCO set up on the front with a modified end link set up compared to what ADDCO supplies. I calculated out that the difference in stiffness between the ADDCO bar and the Revington 7/8" front bar were noise level deltas and that since I already had an ADDCO bar, there was nothing that justified buying the Revington front bar.
TR3driver
I'm just curious, can you expand on that a bit? Yes, it's very simple and a bit hokey; but I don't see any reason it shouldn't work provided the end links are long enough. It only lets you cut the rate; but from what I saw on my TR3A with ADDCO bars front & rear, that's probably the right direction in the rear.
Tybalt
Unless ADDCO has changed it, the adjustable end link kit for the front consists of a pair of bushings for each adaptor plate, a pair for each side of the anti-roll bar, some spacers/distance pieces, cup washers for the bushings, a couple of longish bolts, nuts for the bolts and some little coil springs. I first saw the adjustable link kit when friend got one of those kits to go with his ADDCO bars for his TR250. Essentially, while the set up does allow the bar to be "zero-preloaded," it left a gap that has to close up to before bringing the bar into play. We installed it anyway, but removed it later to go to a more robust set up. As far as cutting the rate of the bar, once the bar is brought into play I don't really see that since the rate for the bar is defined by the length of the bar between the arms, the effective length of the arms, the diameter of the bar and the modulus of elasticity for the bar material.
For the rear of the IRS TR series cars there was no adjustable end link kit offered, just two washers per side, one rather large (2 1/4" OD, 3/8" ID, 1/8" thick per Kastner callout and that sounds about right for what ADDCO supplies), the other not as large (1 3/4" OD, balance same as other washer) that together make the reaction plate for the bar/end links with both fitted into the spring pan of the trailing arm, four cup washers for the upper most and lower most bushings, four link bushings per side plus the hardware for attaching the bar to the frame. The washers as supplied by ADDCO are loose and really should be welded together to provide a more stable reaction plate for the anti-roll bar. Note that other than the washers for the reaction plate, the balance of the Kastner end link set up for the rear is very different from the ADDCO set up but probably not as street friendly since it would cost more ground clearance than the ADDCO set up.
Elott
I have the Ratco front and rear bars. You do not need to weld anything to install the ratco rear bar (perhaps older versions did) but you do need to have the ratco shock-in-coil conversion to fit it. It is not adjustable.
Tybalt
Bearing in mind that I have no first hand experience with the Ratco shock-in-coil conversion, I have a couple of questions. First, do you have one of the Ratco frames with their shock-in-coil conversion? If not, then how is the upper mount for the tube damper handled if you elect to install their shock-in-coil conversion to a TR4A IRS/TR250/TR6 stock frame? The opening in the stock frame upper spring pan is relatively large and something would need to be added so that the damper has something to mount to up top. On the Revington conversion using the stock frame, there are two gussets added to the frame by welding them in along with a plate that is welded in to the upper spring pan opening to act as the damper top mounting plate. I would think that the Ratco conversion has to have something installed as far as a damper upper mount plate goes if you were installing their rear bar to a stock Triumph TR series IRS frame and am curious as to how it is handled.
Tybalt
Thanks for the links to the instructions. When Eddie mentioned no welding required, it seemed that some sort of either large cup washer set up or a flat for the bottom of the upper spring pan and a radiused washer for the top side would likely be employed to make up the upper mount.
I did see in the introduction where mention of additional loads in to the upper spring pan are made. These additional loads were why the Revington kit adds the two gussets from the uprights/vertical towers extending outward toward the upper spring pan for each side. I was somewhat surprised to see carriage bolts swaged into place on the control arm for the lower mount. I do like the bar mounts of the Ratco kit better than the mounts that came with the Revington kit. I wound up scrapping the Revington kit ones and made up some solid mounts with a heat cured molybdenum disulfide solid film lubricant finish applied to the bearing surface.
The Revington kit uses a sandwich plate arrangement for the lower mount with that end of the damper in a double bolt shear configuration as opposed to a pin mount. Upper mount is a pin mount set up similar to the Ratco kit. Attached are a couple of shots, one showing the welded in gussets and upper mount plate, the other shows the modified trailing arm with six satellite holes for the sandwich plate set up and what turned out to be perhaps the most difficult aspect of the project to get right, the damper adjustment access hole. It is that hole along that raised and tapered rib. Lots of time expended figuring out how to approach the task without making a mess of things, but it lines up perfectly with the damper adjustment screw, just had to then make sure and orient the spring in a manner that a coil did not block the adjuster on assembly.
TR4A_IRS TR4/4A TR4 Hardtop - Is there such a thing? Triumph 7
T Post-War Other No such thing as a 1 hour job on a Herald Triumph 8
healeyboz Is there such a thing as Spridgets 4
Y MGB How did become such a mess up???? MG 2
J TR2/3/3A such strange thread on gear shift knob Triumph 12
BlueMax Such is Life Spridgets 11
S New bushings and such on a 76 Sippy Triumph 0
bigjones Compressors and such Spridgets 21
Jim_Newman From under the bonnet there arose such a clatter. Austin Healey 1
lbc_newbie Such a deal! A 3-Fer!! Spridgets 1
bugimike Such a deal!! Spridgets 5
T Doing stuff right is such a pain in the.... MG 9
C So much innovation is such a tiny car! Spridgets 1
Dadandson Post SU Carb Re-Build Revelations and Such Spridgets 4
motofiaccone Springs and such Spridgets 7
T Can anyone interpret such a body no on a AH 100-4? Austin Healey 1
regularman Painting is such sweet sorrow. Spridgets 6
jlaird Blog on oil pumps and such Spridgets 11
jlaird Couple thoughts, question, and such Spridgets 5
jlaird Not such a great part Spridgets 4
T And out in the garage there arose such a clatter.. Spridgets 15
NickMorgan Summer seems such a long time ago Triumph 19
R Crystal Cove and such Triumph 3
Newkie Is there such a car as Austin Healey 15
jlaird Looking for seat covers and such?? Spridgets 9
mezy A thing of beauty Other British Cars 3
Hamish Racing 1963 original racing film British cars doing their thing Racing 0
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
S TR2/3/3A What's a little thing that made a huge difference in your vehicle? Triumph 37
S TR4/4A What is this thing? Triumph 3
Pythias For Sale The Red Thing... Make Offer.. Spridgets Classified 0
60TR3A What's The Weirdest Thing Anyone Ever Said or Asked You About Your Car? Austin Healey 28
J Funniest thing you found working on your car Austin Healey 32
AN5Sprite "Does this thing have airbags?" Spridgets 22
DrEntropy MGB A little thing MG 4
ObiRichKanobi These cars do the damnedest thing... Triumph 12
R Does this thing come off? Spridgets 5
Boink Tonneau Covers - that flappy thing - what is it? Spridgets 17
Mickey Richaud Just the Thing... Other British Cars 21
lbc_newbie Closest thing to a West Coast deal!! Spridgets 4
TR6oldtimer The thing I forgot to do Triumph 2
Brosky TR8 Visors NLA, so I did the next best thing Restoration & Tools 2
BobbyD TRafficator Signal LED Buzzer Thing Triumph 7
mikecyc72usa It's a good thing, right? MG 3
tinman58 Second thing to check Triumph 14
1 What is this thing? MG 10
G One thing after another MG 30
pjsmetana Fuel Filter, anyone got a part # for this thing? Triumph 11
