TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels
TuffTR250
Is there any problem with putting TR6 plastic wheel hub covers and TR6 lug nuts on TR3 wheels? I currently use the big stock lug nuts and stock chrome hub caps. I just got some free black TR6 wheel covers and thought I'd put them on my TR3 just for the heck of it. I want to make sure the TR3 wheels have the same lug nut size as TR6 to ensure this won't wallow out the TR3 wheels and also so the TR6 lug nuts hold the TR3 wheels correctly. Thanks!
Re: Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wh
The nuts should be OK, as long as the studs don't bottom in the nuts. The threads and seats are the same, but the TR3 nuts are open while the TR6 nuts aren't. (I use TR6 wheels on my TR3, but with TR3 nuts & hubcaps.)
I don't see any reason why the TR6 center cap wouldn't fit; but I've never tried it myself. The outer beauty ring I'm pretty sure won't fit, the TR3 wheels aren't as deep as the TR6 wheels. They would look good with the TR3 beauty rings, though, if you can find a set.
Thanks Randall! Most of the time I run TR6 wheels with low profile tires on my TR3 and use silver TR6 hub covers and no beauty rings. So I'm ok with the stud length with the TR6 wheels. I didn't think about checking stud length with TR3 wheels, but I'll double check that. My other concern was if the "taper' and size of the TR6 lug nuts and wheel holes is the same as the "taper" and wheel hole size as on the TR3 wheels.
The reason for my concern is that when I got the car it had some lug nuts that most likely were not correct for the wheels. A couple of the wheels had the lug nut holes wallowed out because the lug nuts did not fit correctly. I had to find two different wheels.
Hello Randall
I see that Rimmer Brothers sell TR6 wheels. I had searched and collected a lot of TR3 wheels to get a set of 5 that ran true. Nice to know that you can get new steel wheels.
David
C TR2/3/3A TR3A Electrical problem Triumph 20
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 27
Sarastro TR4/4A Convertible top installation problem Triumph 12
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
M 1977 MG Midget 1500 Problem Spridgets 8
KVH General TR Transmission Problem Triumph 3
DrEntropy W123 Benz recurring problem Other Cars 16
J MGB Idle problem MG 4
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
Got_All_4 TR6 Throw Out Bearing Fork Problem Triumph 7
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
E MGB MGB heater motor problem MG 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T TR2/3/3A Help - Cooling system problem Triumph 7
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
T General TR Cluthch problem / challenge Triumph 4
M Europa turn signal problem Lotus 7
T TR2/3/3A TR3A clutch problem Triumph 15
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
S Engine or Tachometer Odd Problem Austin Healey 7
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
G windscreen problem Spridgets 1
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
J TR6 72 TR6 starter problem Triumph 10
nichola TR6 New harness installed but have a purple problem Triumph 12
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
C TR2/3/3A TR3 Gearbox Problem Triumph 10
Healey Nut Clutch problem Austin Healey 5
R TR2/3/3A Tr-2 Clutch Problem Triumph 46
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
R TR2/3/3A Grounding problem Triumph 21
P TR6 Wiring problem Triumph 50
P TR6 Clutch problem not solved Triumph 6
D Acceleration Problem Austin Healey 4
M XK120 fuse problem? Jaguar 5
P 2002 Accord problem Other Cars 31
