RickB
I'm posting here because MGB guys have more experience with the HIF carbs than anyone else.
I have owned several MGB's and MGC's but recently have been into the Spridgets.
The one that I put HIF4's on has a 1500cc Nissan motor which is really nice for power and fits well in the engine bay of a Midget being a slightly larger copy of the BMC A series motor.
My only problem is that the mixture screws don't seem to work and the setup runs rich all the time.
I've heard this likely means the o ring for the metering needle is damaged or perished.
I did a float and needle / seat refresh with new lower gaskets on these when I got them and they work very well except for the inability to adjust mixture.
Do they need to be disassembled to replace the O ring that is likely the culprit?
I realize they could use a total rebuild however I don't have another set to bolt on while they are being rebuilt, my plan at the moment is to get my 73 Midget with the 1275 on the road and then put this Midget in the shop and get the carbs rebuilt.
That's not something I can do very quickly.
