Help with value of AH 3000 restoration project
David_K
A fellow car club member has a AH 3000 in his garage that he had a professional restore the body and paint it. The paint is BRG with white two tone. The owner says he choose this but remembers its not correct for the year. Not sure what model year 3000 it is. It has single front marker lamps if that helps. The body work and paint is SHOW QUALITY.
The rest of the car is 95% complete as far as parts. The front suspension and rear axle have been painted black and the car is a rolling shell. Engine is not rebuilt and the interior will probably need replacing. Will need new windshield and top....etc too.
All the owner mentioned as far as price was he wants something in the "teens."
My father and I are great at mechanicals and since the body and paint is finished on this car it is a very attractive project that we could make a turn around on.
Lastly, we have a good friend that is a judge at Healy shows and owns two gorgeous 100 point Mk2 BJ8s. He would help with originality and parts sources.
Will the experts give me an idea on what an engine rebuild and interior costs would be? How much are tops?
THANKS!!!
DavidK, Professionally done:
Complete engine overhaul $7000.00, Top $250-to-$500
Interior $3000.00, Windscreen $250-to-$500, Chrome $2000.00-to-$3500.00.Prices in different sections of the country may vary but not much---Keoke
[ QUOTE ]
Top $250-to-$500
Interior $3000.00,
[/ QUOTE ]
And if you're like me -- with experience from the customer side of this equation (although I haven't had the pleasure of being a customer of Keoke's) -- you must remember to double all estimates, then add 50 percent to that... /ubbthreads/images/graemlins/shocked.gif
The body (fitting) and paintwork were the biggest obstacles for me to overcome. Now I just need the incentive to continue and get the rest of the car finished!
To start a restoration with the body & paintwork behind you would be like a dream! BTW, nice E-36!
Sounds like it would be worth considering....... just were in Tennesse did you say it is? (if the grill bars are vertical it's 1961 and up ,if they are horizonal 57-61)
(I am sure there will be amendments to this)
davidk,i believe the single front marker lamps are indicative of models all the way up to some early bj8's,anyway i think keokes correct about the engine rebuild and i hope when he says "total rebuild"it includes new crank,cam,lifters,pistons,so on and so on,everything if not,im more happy to be living on the "right coast"! /ubbthreads/images/graemlins/yesnod.gif
Thanks everyone for your responses. I'll get an idea on the condition of the other parts and talley up if this project is worth doing.
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
D 68 Sprite value - need help Austin Healey 9
7 TR6 help with tr6 hardtop value Triumph 5
eschneider TR2/3/3A need help - value of TR2/3/4 engine & trans cores Triumph 8
Strapping_Lad Spitfire Help me with the value of this '63 Spit Triumph 22
Scott_Hower MGB Help establishing MGB value... MG 16
timbn2 please help with value of shroud im selling... Austin Healey 12
5 T-Series Value of MGTC... need help MG 4
tr6web TR6 TR6 Manifold gasket help Triumph 1
D TR2/3/3A Please help w this tuneup Triumph 19
D Help with what 4 numbers on MGC VIN mean MG 10
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
