I’ve installed a single SU HIF4 on the stock manifold of a 79 1500 midget. The fuel pump is from AutoZone rated at 2-4 psi. All smog has been disconnected. Can’t find any vacuum leaks. Installed vacuum advance as per Hap's suggestion.
I can start the car but it only runs for a second unless I pump gas to rev it to 4500 then she drops down to 2000 and will die unless I pump back up to 4500. It will not run steady at any rpm so I sit there going 4500-2000-4500-2000. Any advice? Please
Mark
Mark
