HELP! Newbie needs to know how to remove HUBS.
crya
Member
Exactly, I ordered a new set of hubs from BWS and I don't have a manual cause I'm so new and I need to get these hubs off. What's the trick?
The sequence for the front hub is:
1. Remove the grease cap which is down inside the hub opening. This requires a factory tool or you can make your own. There is a 5/16-24 threaded stud coming out the grease cup. I took a 3/4" x 3 1/4" long bolt and drilled/tapped about 1 1/4" deep into the Hex end of the bolt. That gets threaded onto the stud and then use a large washer or plate (to bridge the hub opening) and a nut to pull the grease cap.
2. The hub bearings and shims are held in place by a castellated nut that was under the grease cap. The nut is locked in place with a cotter pin. Shine some light into the hub .. use a screw driver/etc. to straighten the cotter pin and then push the pin out using the holes in the side of the hub and a punch tool.
3. Remove the castellated nut and washer underneath and now you should be able to pull the hub straight off (since you have a BJ8 you also need to unbolt the disk brake calipers first.)
Putting everything back together is not the reverse of the above. There are critical shim adjustments to get the correct zero play in the bearing stack. As Dave said, you really should get the manual but hopefully this will help you get started.
The rear hubs are easier .. remove phillips head screws to take off the brake drum .. unbolt the hubs.
Cheers,
John
L Spitfire Newbie amateur mechanic needs help w/California smog equipment Triumph 6
D Newbie needs help MG 6
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
B TR2/3/3A Newbie in need of help TR3 Triumph 11
Willie_P Newbie HELP: TR 3/4 leaf spring/axle installation Triumph 11
M Help to the newbie - Diff Whine Austin Healey 16
sobamaflyer Newbie - please help with first drive impressions Spridgets 19
BevCox Newbie.. Help please Triumph 5
tr6web TR6 TR6 Manifold gasket help Triumph 0
D TR2/3/3A Please help w this tuneup Triumph 18
D Help with what 4 numbers on MGC VIN mean MG 10
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
