TR2/3/3A Help needed with info on vintage TR2 race car
Summers
Hello there, i am 20 years old and im new to british cars so bear with me.
I just purchased a vintage TR2 race car. It was called the gibbons or gibson special (unsure of the spelling). I found it in a storage building in northern cali. Im still waiting delivery so i dont have all the info on it. It is supercharged, all aluminium body and use to race competively, all though i am unsure how long ago. It needs a few things but i am going to try to put it back on the track with in a few months.
Any information on its history or anything like that would be greatly appreciated.
figured it out... here pics...
Summerslee
https://s832.photobucket.com/albums/zz243...pg&newest=1
TR3driver
Great Pumpkin - R.I.P
Andy, he was trying to link to Photobucket. The link works, but it is to a web page, so the image doesn't show up here. To get the image to show up, you need to get an 'IMG' link code, eg
{IMG]https://i832.photobucket.com/albums/zz243/Summerslee/triumphengine.jpg[/IMG]
Sorry I can't help much with the car. ISTR Gibbons used to offer "kit car" bodies, and appears to still be in business, you might try contacting them to see if they know anything : https://www.gibbonfiberglass.com/
From the pics, it looks to be a fairly stock TR chassis & motor (except for the motor mounts being moved back and the R&P steering), with a Judson supercharger on it. Starter & gearbox appear to be early TR3, while that's a TR4 (or very late TR3) rocker cover.
It also looks rather unfinished to my eye, which leads me to doubt it's racing history somewhat. For example, I see no brake lines at all, except for one front brake hose that seems to be hanging in space. The red overspray on the motor mount seems suspicious to me as well. No throttle linkage, no exhaust, no power to the starter ... and what's with that pile of anodized fittings on the heater port? There's obviously no heater. Where does the radiator go? The hood sitting on the air cleaner seems like something that wouldn't survive a race, either.
S
Summers
From wat ive got. the guy was in the middle of restoring the car after somethings happened to it. The owner died and car was put in storage. The radiator was robed off and put on a hot rod, already having a new one made, the engine is suppossed to run really strong. The airfilter was just slapped on it to prevent anything falling in carb/intake. It is suppossed to be mostly stock chassis. Radiator sits just infront of steering rack... Think it was worth a few grand for a track car?
TR3driver
Sure, if that's what you want. Should be a lot of fun, once it's back together.
TR3driver
Hmm, I thought there were some 'before' pictures of Peyote on the net, but I can't seem to find them now. But if you want, try poking around here and see what you can find. Peyote started out much like what you have; in fact it's possible that Bill or one of those guys will recognize the car.
ekamm
I've a pic of the car that you bought on here before. It seems like it was on BaT or Craigslist.
cheseroo
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Probably makes them 14"[/QUOTE]
fwiw- The 1981/82? 280ZX turbo came with 15" wheels that will bolt up to a TR
aeronca65t
Yeah, I can't find any "before" pictures either.
There are actually a number of TR2 and TR3 "specials" out there.
If I had to guess, I'd say this Gibbons Special is a newer-built replica of one of those old specials.
Anyway, here are pictures of Bill and Peyote that I took at the Pittsburgh Vintage a few years ago (yes, that's a TR3).
Technically, Bill is a member here.
By the way, here is my favourite TR3 Special. The Ambro Special (he ran with us at The NJ Historics at NJMP last year). Hard to believe this is a TR3.
DNK
IIRC, there use to be a Peyote that ran at Summit Point
TR3driver
Me too !
:iagree:
billspit
fwiw- The 1981/82? 280ZX turbo came with 15" wheels that will bolt up to a TR [/QUOTE]
Those are ZX wheels on the car.
toysrrus `94 Jag XJ6 Console info. needed: Please Help: Jaguar 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
E GT6 Help electrical guru needed Triumph 4
R Rust in Block? Help needed! Austin Healey 6
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
J BJ8 Turn signal help needed. Austin Healey 6
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
T TR2/3/3A help needed! fuel problem Triumph 25
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
F General MG Help needed with su dual carburetor identification MG 4
S Wedge TR8 Starter wiring help needed Triumph 18
TomMull Air compressor help needed Restoration & Tools 2
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
Lukens TR2/3/3A help needed Triumph 6
A Fuel Gauge - Help Needed Austin Healey 18
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
E Singer wood frame help needed. Other British Cars 3
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
A BJ7 - Help Needed Austin Healey 3
Lbp TR2/3/3A Painting Help Needed for Restored Steering Wheel Triumph 5
J Any SP250 owners with Austin Healey [big] rearends e-brake help needed Other British Cars 4
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
B Help Needed with Upholstry Problem! Austin Healey 19
S BT7 Dash Gauge Light Bulb Replacement Help Needed Austin Healey 16
Tinkerman TR2/3/3A Air Deflector Installation Help Needed Triumph 19
B Looking for passenger side rear marker light module-and lots of fixes/help needed pls Spridgets 13
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
A Serious help needed !!!! BJ7 Installing a new soft top Austin Healey 9
Tinkerman TR2/3/3A Parts help needed 1960 tr3 a Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
Tinkerman TR 3 Picture HELP Needed Triumph 5
S Help needed... Sunbeam (Rootes) 7
S Lower Wishbone Fulcrum Help Needed!! Austin Healey 26
S 3000 BT7 Steering Wheel Restoration help needed Austin Healey 3
Tinkerman TR2/3/3A TR3A Seat spring set needed, Help Triumph 6
C Mallory dual point recurve help needed Austin Healey 6
Tinkerman Speciality Paint Help Needed Triumph 4
TR4A_IRS Help needed with high idle Triumph 13
Kleykamp TR2/3/3A TR3 Generator mounting issues help needed Triumph 4
Wirewheels Remote purchase help needed! Triumph 8
S Spitfire Spitfire front suspension help needed Triumph 9
R TR 3 Conv. top help needed Triumph 10
M Help Needed. Alternator Question Spridgets 14
rcufley A little ignition help needed Triumph 123
6 Rear brake help needed Austin Healey 10
