MGB Help needed from new 65 MGB owner
bighealeysource
Bronze
Help y'all,
I have just purchased a nice restored 65 MGB and looking to change out the incorrect black vinyl seats for the correct
for this car red with black piping leather. Owned a lot of
Brit cars over the years and went to take out the seats and
not as easy as I thought. Is the only way to get the seats
out is by taking the entire seat frame assembly out ? Plus
I have one 1/2 inch bolt that is turning but not loosening
on the right side passenger seat rail so that has me stumped
as it is not accesible from underneath - covered by a frame rail. Any help would be really appreciated or looks like I stay with the black vinyl !
Regards,
Mike
1965_MGB
It is true that you have to take out the entire frame to get the seats out. The bolt you are having trouble with is covered by a frame rail. You may need to hack off the head of the bolt, or do as some here have, and drilled a hole in the crossmember to get at the capture nut.
Are the current seats in good shape? If so, there may be someone here (like me) that is looking for a good set of seatcovers :smile:
bighealeysource
bighealeysource
Bronze
Hey Ron,
Semper Fi to you too !!!! I live in Beaufort, home to
Parris Island so have a lot of Devil Dogs as friends.
I wasn't one myself, I was an Air Force puke !
As to the seat covers, they are actually brand new, from
Moss. If I can get them off I am trying to get this car
back to original of red with black piping and red with black
piping on the panels ( actually still have some of the originals) If I can get them off, I will make you a great
deal on them. Don't know about hacking off that bolt head
as think I would have to use plastique to get it off but
worth a try I guess. If I'm successful I will get back
to you about the black vinyl seat covers.
Semper fi,
Mike
Platinum
MIKE!!! A Dremel with a cut-off wheel and patience!!
...just some advice from a fellow USAF puke... :wink:
Sounds as if the PO grabbed anything he found to anchor the seat. 1/4-28 was original. There are aircraft fasteners around to allow you to drill out the bugger'd captured nut and insert a 1/4-28 in its place. It may be necessary to "hole" the cross-member to remove the spinning nut, tho.
bighealeysource
bighealeysource
Bronze
Hey,
Thanks for the advice about a demel, I've got one so that
sounds like a winner. Next question, I get the front ones
off, how in the world do you get to the rear ones without
being a contortionist. I move the seat as far forward as
it will go and still can't get to them.
Thanks,
Mike
there's a small square of metal inside the track (toward the front of the track) that can be unscrewed, it will allow you to slide the seat farther forward. I completely left mine off when I installed my seats.
Platinum
Or use this as an excuse to acquire MORE TOOLS! A 7/16" GearWrench works a treat. :wink:
1965_MGB
I have to look into these GearWrenches I keep reading about. I see Lowe's carries them. I guess I am going to take a ride out there and pick up a few of the wrenches.
jackq
I have one tool box that has a few drawers dedicated to gear wrenches...standard and metrics, regular lengths, stubbies, offset head types, don't know how I went so many years without them.
1965_MGB
I picked up a couple of the gearwrenches today. Just a 7/16, 1/2 and a 9/16 to give them a go. I only used the 1/2 today to put my high note horn on, and it worked pretty well. Time will tell though. But for the price, I find that they will come in handy.
19_again
I buy my at Sears, made in the USA! I really look for reasons to use my swivel head 7/16th, They don't mark the visible, painted nuts and bolts like valve covers, etc.
Steve_S
The Craftsman version of these wrenches are far nicer than the Chinese Gearwrench version and imho are worth every penny. The head flexes and locks into any position which is a feature that will pay for itself in no time. If the extra bit of money isn't a problem, you will thank yourself for the rest of your life for buying them! And I do agree, these are the best tool for removing MGB seats.
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
E GT6 Help electrical guru needed Triumph 4
R Rust in Block? Help needed! Austin Healey 6
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
J BJ8 Turn signal help needed. Austin Healey 6
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
T TR2/3/3A help needed! fuel problem Triumph 25
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
F General MG Help needed with su dual carburetor identification MG 4
S Wedge TR8 Starter wiring help needed Triumph 18
TomMull Air compressor help needed Restoration & Tools 2
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
Lukens TR2/3/3A help needed Triumph 6
A Fuel Gauge - Help Needed Austin Healey 18
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
E Singer wood frame help needed. Other British Cars 3
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
A BJ7 - Help Needed Austin Healey 3
Lbp TR2/3/3A Painting Help Needed for Restored Steering Wheel Triumph 5
J Any SP250 owners with Austin Healey [big] rearends e-brake help needed Other British Cars 4
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
B Help Needed with Upholstry Problem! Austin Healey 19
S BT7 Dash Gauge Light Bulb Replacement Help Needed Austin Healey 16
Tinkerman TR2/3/3A Air Deflector Installation Help Needed Triumph 19
B Looking for passenger side rear marker light module-and lots of fixes/help needed pls Spridgets 13
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
A Serious help needed !!!! BJ7 Installing a new soft top Austin Healey 9
Tinkerman TR2/3/3A Parts help needed 1960 tr3 a Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
Tinkerman TR 3 Picture HELP Needed Triumph 5
S Help needed... Sunbeam (Rootes) 7
S Lower Wishbone Fulcrum Help Needed!! Austin Healey 26
S 3000 BT7 Steering Wheel Restoration help needed Austin Healey 3
Tinkerman TR2/3/3A TR3A Seat spring set needed, Help Triumph 6
C Mallory dual point recurve help needed Austin Healey 6
Tinkerman Speciality Paint Help Needed Triumph 4
TR4A_IRS Help needed with high idle Triumph 13
Kleykamp TR2/3/3A TR3 Generator mounting issues help needed Triumph 4
Wirewheels Remote purchase help needed! Triumph 8
S Spitfire Spitfire front suspension help needed Triumph 9
R TR 3 Conv. top help needed Triumph 10
M Help Needed. Alternator Question Spridgets 14
rcufley A little ignition help needed Triumph 123
6 Rear brake help needed Austin Healey 10
Brooklands MG Parts ID help needed MG 4
