TR6 Headlight size
Healey Nut
Hi All .
posting this here as I’m looking for some help with an Austin Healey project .
Im building a 1962 Healey 3000 Mk 2 Tri carb rally recreation .
It will have reproduction high level rally lights mounted on the front shroud.
I have the light pods from Dave Hardwick in the UK but I need 5 3/4” headlight buckets and all the other associated bits n pieces to create the fog/spot lights .
the pods have an OD of 7 1/4” and the hole for the light bucket is 5”
Do any of the Triumph cars have headlights of this size ?
The main factor is the outer diameter of the chrome trim ring so it blends properly with the light pod .
tks
I have been in contact with Holden in the UK .
They can supply everything except the chrome trim rings , so I’m searching other makes to find an alternate solution .
I don’t want to get parts from Holden and find that trim rings from another source won’t fit .
my main question is the OD of the trim ring where it meets the body I need it to be 7 1/4”
If you are asking about Moss part # 560-210, it's tapered from a max of 8 1/4" OD at the bucket tapering forward around the lens to 71/4
Just trying to think a bit different.
would a British bike headlight ring suit ?
Sorry seems the larger dia. Is 6”
Motorcycles use the smaller stuff lights and such; probably not get anything to hold it in place, but maybe standard regular tr3 stuff would work for mounting to body.
I have emailed an old British bike supplier to see if they can help but I will check the TR3 stuff out .
I was under the impression that TR5/6 had 5 3/4” headlights .
Does anyone know which British cars used 5 3/4” headlights ?
The headlight unit and bucket etc isn’t the problem , Various suppliers have them the chrome trim ring is the issue .
I need to find a trim ring that will fit with whichever bucket etc I use and that has a 7 1/4” diameter back edge where it will meet the light pod so it looks correct .
There seems to be some misunderstanding about what Im looking for .
see attached , chrome trim ring , this is what I need but the edge to the left of the screw holes needs to be 7 1/4” diameter to fit flush with the edge of my light pod . The hole that the headlight unit fits through needs to accept a 5 3/4” headlight unit .
I can get this from Holden in the UK and also other suppliers elsewhere . Holden don’t have the finishing trim rings .
I understand exactly what you are looking for. You want headlamp doors for a 5 3/4 headlamp unit with a rear OD of 7 1/4 to match your body work housings. I can't think of any Triumphs that used 5 3/4" headlamps that didn't incorporate the headlamp doors into the grill work or had them as combined units for both the inner and outer headlamps. I have been running different cars through my brain and everyone that I come up with that used the 5 3/4" headlamps either had headlamp doors that were siamesed together or if separate units, they were contoured to the cars and supplied by the vehicle manufacturer so no out of the Lucas catalog headlamp door to fit the headlamp that I thought of off hand. So I have even gotten out my collection of old Lucas catalogs and started going through them trying to chase down a specific application that might just scratch that itch for you. So far, no such luck.
I still have a couple of smaller (fewer model ears covered) old Lucas catalogs to go through but at this point, I'm not holding much hope of getting a lead from them. Even though my father had a couple of big Healeys when I was a kid, not really spent any time chasing down stuff like this for them before. In the Triumph end of the world we have outfits like Revington TR and Racestorations in the UK along with a smattering of serious performance parts folks in the US. I would have to think there are probably similar outfits servicing the needs of the Healey end of the world that might be able to help you out.
In any event, I'll get through those other old Lucas catalogs in the next few days and report back on the results.
Were there ever any bezels that size or profile.
what governed the size of the opening in your new pods you made ?
the picture I posted of the red rally Healey obviously smaller lights and most likely the 5 3/4 but 7 1/4 opening ?
Pain in ar@e but perhaps make the pods to a known and available light fitting and bezel ?
The pods are copies of the originals as used on the Healey rally cars . The opening is NOT 7 1/4” the OD of the pod is 7 1/4” so the back edge of the trim ring where it meets the pod needs to be 7 1/4” so it fits and flows properly to look correct .
There is a split ring type that screws together at the bottom on the outside; you might be able to do something with that--- They have been around for a long time. Maybe the 1950ies but the 1960ies I would bet.
Just for point of reference see attached .
Its a pic of the replica rally pods from Dave Hardwick with a 7” standard Healey headlight bucket and trim ring perched on top .
So that’s my dilemma .
I checked into the low light Morris option but they appear to have inset lights so minimal trim rings , I need to have trim rings like the 7” Healey ones but in 5 3/4” light unit size .
I do have a some old 7” ones so I may take them to my metal guy to practice on to see if he can cut and reduce them by rolling them on the English wheel .
No joy in Mudville, there is nothing in any of the Lucas catalogs that helps. In fact, for the 5 3/4" headlamp units, Lucas shows no headlamp doors in any application. This says to me that for the limited number of quad lamp set ups on British cars the headlamp doors were either supplied through the car manufacturer as singles or as dual lamp units or made as part of the grille. I was hoping to at least point you in some direction to search.
At this point, you have just stated what my suggestion would be of going to a panel beater and seeing if they could fabricate something up for you. Best of luck going forward on your project, I'm confident that it will look rather sharp when completed.
Tks for looking , you can follow progress on my project using the link above .
So the word from Holden in the UK is that I’m looking for Lucas 552822 and they are “rare as hens teeth” .
It is a good number and I can find reference to it on Google . Its a pinch ring type trim ring but it appears at the moment that it maybe unavailable .
The search continues………
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
F TR2/3/3A Headlight bucket color Triumph 22
F TR2/3/3A Headlight bucket clip Triumph 2
Healey Nut Headlight buckets Jaguar 3
B Headlight Dip Switch Austin Healey 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow For Sale Used headlight rims for sale Austin Healey Classifieds 1
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
Guido36 LED Headlight Upgrade Austin Healey 1
D BJ8 Headlight Rims Austin Healey 0
D TR2/3/3A snap on headlight rims restore Triumph 10
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
dbenichou289 TR2/3/3A headlight switch removal Triumph 10
Spock TR6 '72 Headlight Relays Triumph 4
Upland 3 position headlight switch is now 2 Spridgets 1
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
D TR2/3/3A Headlight Trim Triumph 17
P TR6 ^%$#headlight rim Triumph 4
KVH General TR Headlight going out Triumph 9
Rob Glasgow Weird Lucas Headlight Austin Healey 7
D Wanted TR3 Headlight [lamp] chrome rim Triumph Classifieds 1
P TR6 Headlight problem Triumph 3
M Headlight relays Austin Healey 17
T TR4/4A Attaching headlight trim ring Triumph 6
S TR4/4A Headlight switch wiring. Please help Triumph 2
GTP1960 TR2/3/3A LED headlight question Triumph 11
K TR4/4A 4A chrome headlight rim installation? Triumph 2
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
S TR2/3/3A Tr3 headlight buckets Triumph 3
healeyblue XK 120 headlight mounting Jaguar 1
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
4tecdog Headlight relays the easy way Austin Healey 13
M For Sale E-Type S1 Plexi Headlight Covers Jaguar Classifieds 0
Rut Headlight relay question Spridgets 3
JPSmit Question four - headlight trim ring Spridgets 9
princetn1 MGB Headlight Grille MG 7
TomMull General Tech Headlight upgrade Triumph 9
S Replacement Headlight Switch Spridgets 4
jaegzie Headlight buckets Spridgets 3
B Sizes of Headlight Bucket Recess Austin Healey 8
CJD TR2/3/3A Headlight bulb rating Triumph 18
Tinkerman TR2/3/3A 1960 TR 3A square spier nuts on headlight assembly Triumph 2
C TR2/3/3A Weak headlight Triumph 7
J TR2/3/3A Headlight choices, Carillo shells Triumph 1
