Have I lost my mind???????
terriphill
OK, as you know, I bought an 80 B a little over a year ago. It supposedly ran (it didn't) and it was supposed to be original (it wasn't). We have spent the last 13 months getting the motor reworked, running and new interior installed. But the body is another whole can of worms that we now have to address. I should mention, mechanics and interior are not an issue for us...body work is another thing.
We have recently found a perfect shell of a 1979B. It is an immaculate body with no rust and straight. The guy has sandblasted, primed and painted it. Basically its a shell on wheels...The wiring is in tact, but he has removed everything else.
So, we are thinking about buying it and transferring the motor, transmission, exhaust,trim, lights and interior from our 80 B to this one.
I know this sounds crazy, but the body on our 80 has been nothing but one rusty little surprise after another which we have cut, welded, patched etc and we are not really pleased with our handiwork.
I guess the question is how much of a hassle would it be? I mean, its a shell ready to be rebuilt and we have all the parts to put on it....opinions?
Terri;
If it is as good as you think, and you're not afraid of the changeover,
Do It!!!
I think it will work out for you.
Dave :savewave:
I'd go for the switch - you'll have a car you like and you'll have it sooner
Switch everything, Terri....& crush the old body when you get finished with it....but, pull att the tags before you crush it!
I'd say go for it. I'm going to go ahead and tell you though, you're going to be buying a lot of new parts. You'll pull ones off of your current car, put them against that shiny new body and realize they're not up to snuff. It happened to me. You'll have a great looking car in the end though.
Same sentiments from me. Go for it. Since it is basically a nuts and bolts operation the work isn't all that difficult and progress is rapid.
One pain with panel work is you basically end up going in a circle.
Pull parts off , find rust , cut out rusted area , fit and fix new tinware , prep and paint and then refit the hardware you took off in the first place.
A lot of time and effort and you are basically back where you began.
Give me an engine rebuild or a clutch replacement any day !
Cheers , Pete.
Veni , Vedi , Velcro.
I came , I saw , I stuck around.!
Ex digitum et nil illigitimum carborundum !
Cheers , Pete.
Amen to that! We have rebuilt 4 cars...but they all had good shells to start with. Motors and clutch, even interior seats and dash were a breeze compared to the issues we are looking at here. I truly understand what y'all mean now when you said these cars rust from the inside...the outside looks ok, until you start to sand on it and then you discover more rust where the water sat inside the frame. One positive note...I certainly am becoming better at what to look for in future projects.
Ditto me, if the 80 shell is as rusty as you say you will have to take a lot of stuff off, do rust repair and bodywork, which on the unibody MGB is a lot of time and complicated sheetmetal work to do well, the sills for example. This will take you lots of time and skill to do yourself, or major bucks to pay someone else to do it.
So swapping out the mechanicals to the good car should be less work with a better result--and you will get a chance to know all the systems and assemblys on your car really well!
I agree with everybody else. You need to have a solid base for your restoration. A rusty hulk isn't one.
As to your original question "Have I lost my mind???????", I think that is self-evident, as proven by your association with people that post to www.britishcarforum.com. :crazyeyes:
Well, we spent the past two weekends erasing the past year's work. I now have a MGB in boxes in my dining room, a motor and transmission in the garage and a very intricate knowledge of how these cars are assembled.
This is definitely the only way to do this. I think a media blasted and painted shell that we can assemble will definitely produce a final product that is what we want and taking it apart first is a great learning experience for reassembly!
We have to get the 80 out of the garage now and then we will post pics of the new shell once we get it home.
Thanks guys!
Rut I’ve lost my mind, or what’s left of it! Spridgets 12
judow Hello, I just lost my mind!!! Austin Healey 10
Basil Mickey have you lost your mind? Triumph 11
D TR6 lost body shell Triumph 1
pbraun Moke America lost trademark name "MOKE" Other British Cars 0
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
G TR2/3/3A Finding a long lost TR3 Triumph 4
Got_All_4 TR5/TR250 Lost Turn Signals Triumph 2
B Lost Title Woes Restoration & Tools 9
B Lost & Found FORUM Navigation Questions 3
D Long Lost Midget Spridgets 0
E Long lost Sprite Spridgets 10
Northcoaster TR4/4A Lost info on person interested in my valve cover Triumph 1
steveg Steve Kingsbury has lost everything. Austin Healey 11
mgedit TR2/3/3A Lost Spark Triumph 26
RAC68 Lost 8 terminal Flasher Relay Plan Austin Healey 39
Basil Lost a member - Blueghost Spridgets 9
P TR6 Lost posts Triumph 3
F Looking for Long Lost BJ-7 Austin Healey 2
DrEntropy We've apparently lost another one Racing 1
J Stator tube lost in steering box Austin Healey 11
YYCDave TR2/3/3A Lost Triumph Found Triumph 5
L TR2/3/3A Tr3a lost power go uphill Triumph 21
Boink Great day for a drive... even if briefly lost. Spridgets 0
Lukens TR2/3/3A Lost a hinge pin on my TR3 Triumph 3
T lost in the forms FORUM Navigation Questions 2
aeronca65t Lost a great friend of vintage racing. Racing 1
DNK I have compleately lost it... Triumph 73
wangdango Lost BN2? Austin Healey 1
bobmga62 Lost 4th gear at high revs Triumph 10
8 Lost 3rd & 4th Gear ?? Triumph 18
Jer Spridget's are like a lost Puppy... Spridgets 17
W Lost part, look for help and or options Triumph 9
S Wedge Lost stray, TR7 to 8 parts Triumph 11
T BJ7 -lost reverse, then 3rd/4th - advice please! Austin Healey 10
J I've lost Reverse! MG 13
78Z Lost luxury - Austin P Spotted 3
G 1500 Dual Carbs in, rims lost in space... Spridgets 12
R lost 1st and 2nd! Spridgets 10
tahoe healey lost boys Austin Healey 10
jvandyke I've lost 4th gear! Spridgets 36
bthompson I've lost second gear!! Spridgets 95
G Lost spark [ Best ignition coil for a stock '79] Spridgets 18
Stewart I think I've lost it MG 15
DNK Have We Lost a Member Triumph 30
G Lost part Triumph 10
TonyPanchot lost oil pressure help please Triumph 23
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
M Lost out on Bugeye Spridgets 37
rick_ingram Enthusiast lost MG 1
