Get oil pressure gauge fixed or just find another
They are fairly common and can usually be found for under 25$ on ebay, just ask the seller to make sure it is in proper working condition. I just got one for 22$ there and it works perfect.
<span style='font-size: 17pt'>and it looks identical to the other gauges!</span>
I second that. Used and operational will cost less than rebuilding. When searching eBay, broaden your search to more than TRs. You'll probably find identical Smiths/Jaeger gauges used on several LBCs. Periodically NOS gauges show up on eBay and as long as the seller hasn't got pipe dreams on their value, these can be great buys.
Anyone who owns an LBC has a closet, garage, or attic full of parts that they assume someday they'll fix or need. Broken gauges would certainly fit that category. However, I wouldn't think you'd ever consider installing a gauge that has a needle permanently resting on 60 psi.
When I started re-doing the gauges on my TR3 resto project, my oil pressure gauge was sitting there reading 30 psi. I took it apart and found that the needle mechanism was displaced from where it should have been. I reassembled everything properly, and the needle was then at the zero mark. I blew compressed air (set at 80 psi) into it, and the gauge read real close to that. So maybe the gauge just needs some TLC. It won't hurt to take it apart and see if anything is amiss that is easily correctable.
My TR3 came with a TR4 press olio gauge. I replaced it and looked at the TR4 gauge sit on the shelf for a decade or so. Finally sold it on eBay for about nothing just to get it a good home. As these gauges are generally trouble-free, long-lived and cheap... used makes sense to me.
Re: Get oil pressure gauge fixed or just find anot
Larry, as usual, I will take a different tack. Knowing you and your careful attention to detail, I feel you will be better served by sending your gauge in to a good rebuilder such as Palo Alto (I have great luck with Nisonger myself) and have it done right. How much could it possibly cost, in the big picture of things. Changing out a someone else's used gauge is a real PIA. Get it done right and forget about it. To me, the two most important gauges on your dash are, in order of import, are the oil gauge and the water temp gauge. Just me.
I've two cars with the dual mechanical OP/temp gauge. I've sent more than a few to Nisonger for refurb over the years, both mine and clients' gauges. Hard for me to trust a "used" unit for what (as Bill pointed out) are the two most crucial instruments. I have a rebuilt/recalibrated one in the "spares" bin now.
Please don't misinterpret my comments, I do not wish to offend anyone.
Checking an oil pressure gauge is as straightforward as Martx-5 said. I occasionally bench-test/calibrate pressure gauges in my garage. I have an accurate reference gauge mounted in a 'T' to which I connect a regulated compressed air supply and the Smiths/Jaeger gauge I'm working with. With care and the correct tools like this it's not only possible to confirm the proper operation of a pressure gauge, you can recalibrate it. As mentioned above, these gauges are usually trouble free and when something goes wrong it can be fixed as long as the bourdon tube isn't damaged. (I'll admit there have been one or two gauges I've binned because of binding in the pinion gears... but they are the exception).
Opening gauges is a bit different from opening a transmission or rebuilding an engine. To have confidence in your work you need a few tools that aren't normally part of your tool box. However, in a lot of cases, the repairs and recalibration are not beyond the capabilities of those who repair their own LBCs. However, like transmissions, I admit it isn't for everyone.
Back "in the day" used car dealers would "fix" low oil pressure problems by taking off the gauge cluster glass and bend the needle to indicate a little higher oil pressure reading.
Buyers only cared how much pressure there was at an idle or driving down the road...I never saw anyone complain that there was too much oil pressure when the engine was shut down...
Being a Concours nut, it would really bother me to see a dash with one gauge that is condition wise completely different from the other five. If you buy used and need to have it restored, the result will be like a grass stained pair of sneakers with your favorite Hart, Shaffner & Marx.
Lou Metelko
Auburn, Indiana
When it comes to restoration, concours, and antiques, which is preferred... a pristine restoration (bright and new), or a car in relatively good shape with patina showing its age? This isn't a comment, it really is a question. I've heard both arguments from collectors. I only bring it up here because of Lou's comments about the contrast between reconditioned and used parts.
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
JimTR4 TR4/4A Oil pressure gauge hose Triumph 5
T Oil Pressure Gauge Not Reading Spridgets 8
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
K TR2/3/3A Oil pressure gauge readings? Triumph 9
M TR2/3/3A Oil pressure: the gauge? Triumph 4
Rut MGB Oil pressure gauge leather washer MG 13
Geo Hahn TR6 Oil Pressure Gauge Triumph 4
maxwedge5281 oil pressure gauge line...urgent!!! Austin Healey 10
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
M TR2/3/3A Reading oil pressure gauge Triumph 3
K GT6 Spitfire oil pressure gauge readings? Triumph 4
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
NardisCNC Oil Pressure Gauge Questions..... Spridgets 8
JimTR4 Electric oil pressure gauge Triumph 20
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
T Oil Pressure Gauge braided line failure Austin Healey 6
S TR2/3/3A TR3A Oil Pressure Gauge Leather Gasket ?? Triumph 11
D Oil pressure gauge flex hose. Spridgets 29
Stewart Removing the rectangular oil pressure gauge MG 5
sail Oil Pressure Gauge Stuck Triumph 4
60TR3A Leaky Oil Pressure Gauge Triumph 14
E Oil Pressure Gauge Pipe Fitting Spridgets 7
E Bugeye Oil Pressure Gauge Spridgets 5
tmc oil pressure gauge and line Triumph 5
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
hondo402000 TR6 TR6 71 Oil pressure gauge Triumph 3
R Oil Pressure Gauge MG 3
W Oil pressure pipe - gauge to flex hose P/N 2A5640 Spridgets 10
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
T 1500 oil pressure gauge leaking Spridgets 6
RickB Oil pressure gauge scared me last week... Spridgets 3
M Oil Gauge reading high pressure MG 3
RickB Dual temp / oil pressure gauge - how to remove? Spridgets 18
Atrus Oil Pressure fitting thread size [calibrate gauge] Spridgets 15
