As many of you know, I just about have my restoration complete. However, I encountered a problem this week that I have yet to solve. The water drain tap on the LH side of the block (not the heater valve) begins to leak when I get to about 165 degrees. Slow drip at first and then more rapid. Coolant all over the garage floor!
I was using the original drain tap, so I ordered a new one to try. It leaks also!!!!
Have others of you encountered this? What suggestions do you have for fixing this. I can take it out and give the end a whack with a punch to try to "set" it in the valve. It is not easy to get to as it is behind the exhaust headers, heat shield and carbs. I did find that I can approach it from the front of the car.
I need help!!!
Lin
1960 BT7 in restoration
1959 Bugeye
I need help!!!
Lin
1959 Bugeye
