front shroud templates for 3000
BoyRacer
Has anyone made templates for a 3000 front shroud? I am doing a restoration on a BT7 and the shroud has been massaged a few times over the years. I don't t know what is right and what is wrong. I have made some templates to compare with two other shrouds that I have. They are all out of shape. I need a set of accurate templates so I can fix all 3 shrouds to the proper shape..
HealeyRick
Admittedly, I have no idea what this would cost, but one of the local high-end restoration shops has a 3D laser scanning set-up that allows them to scan a vehicle to accurately reproduce parts. If no one has templates already, maybe you could have a car with a good shroud scanned. Here's a place in Portland that has the capability to do vehicles: https://www.laserdesign.com/locations Can't wait until I can scan AHS=3504 and 3D print it out.
Healey Nut
maxwedge5281 Front Shroud Differences: 3000 vs. BJ8 Austin Healey 5
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
Jake BN1 Front Shroud Badge - What is original? Austin Healey 4
Marvin Gruber Front shroud piece needed Austin Healey 16
Healey Nut Front shroud badge Austin Healey 66
B Fitting grille surround to front shroud - BJ7 - any advice? Austin Healey 21
B Painting underside of front and rear shroud - Original prep and color? Austin Healey 3
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
E relief map of lower front shroud 61 bt7 tricarb Austin Healey 0
germanmichel BT7 shroud connecting at front frame rail plates Austin Healey 6
T Front Shroud Qustions Austin Healey 8
T 1955 BN1 front shroud Austin Healey 3
T Austin Healey front shroud FORUM Navigation Questions 1
H front shroud-pls clarrify holes for me thanks Austin Healey 9
O front shroud work in Northwest Austin Healey 5
H Wheight front shroud Austin Healey 3000+transport Austin Healey 18
richberman Pictures of BN4 front shroud/chassis joint Austin Healey 5
J Healey BJ8 Front Shroud Phase1 / Phase2 ? Austin Healey 7
Y Restoring a 58 100 six front shroud Austin Healey 1
T Front Shroud Adhesive Austin Healey 10
T 100 Front Shroud Attachment Austin Healey 0
J front shroud to fender welt Austin Healey 4
C Front apron to shroud clearance Austin Healey 21
B Front Shroud 1974 Spridgets 10
Bob Claffie Front shroud asm Austin Healey 5
timbn2 Front Shroud for 100 Austin Healey 2
AUSMHLY Rain channel screws, front shroud Austin Healey 1
AUSMHLY Front Shroud replacement Austin Healey 28
S Front shroud and fenders Austin Healey 12
N BJ8 front Shroud Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
