Front Shroud 1974
blkcorvair
I picked this 1974 shroud up on ebay. I want to use it on my 76 tub and already cut and smoothed the frame rails, but I am trying to make this tub look like a pre-rubber tub. Any one have a pic or two of a chrome bumper car with the front fenders and hood off so I can see what this arear of the car is supposed to look like?
ChrisS
The color doesn't lend itself to clarity but try these. Not that the radiator support has been modified for a different radiator.
B
blkcorvair
Those pictures are invaluable. Many Thanks! It appears that there are some extender pnels on mty car that just need to be worked off. Does the front shroud assembly attach to the radiator supports? On the 76 it is a welded piece at top and bottom.
BTW that is a fine example of a project!
ChrisS
The shroud bolts to the inside edge of the radiator support. If you look close on the outside you can see three nuts that are welded to the radiator support.
tosoutherncars
That's too funny... I got the passenger-side fender from the same car (as a prelude to a chrome-bumper conversion.) Our cars are going to be related! hehe
B
blkcorvair
That is too funny! Turns out Im not going to use many of the parts from my orange midget once Ive got my other going to Ill give this forum first dibs before anything hits ebay. Thats a while out though. I must say the gentleman that built my engine really put some time and money in it. Its a shame but a 1275 or 1098 will do me justice
jlaird
So, tell us about the engine.
Bruce_B
If you're looking for a 1098 engine, I've got one in my garage that I bought off of Ebay. PM me if you're interested. I think I have the write-up/pictures that the seller posted.
I can email those to you.
Or anyone else whose interested. It's a full engine. No flywheel.
B
blkcorvair
Im going to hold off a bit til I get the tub finished, Then I'd like to disemble the test car keep or part out its various bits and make room to spread out for an engine build. Be about 8 months or so yet. As for the 1500 that's in my bondo buggy, (Mind you I bought this car for $600 with most of the reciepts.)
Balnaced the rotating assembly.
Lightened/ Balanced the flywheel,
Oil feed line kit to drockers
Flat top pistons
1500rpm+ New Cam
4into 1 header (Dont know who's)
3 angle valve job, new valves
new water pump, oil pump,Timing Set, New Bearings
New Clutch and Pressure Plate,
New Slave cyl., new throwout & piolet Bearings
Backup Elect Fuel Pump.
Weber Downdraft (The one pitfall)
Summit Regulator, Liquid press. guage.
Oil Cooler and spin on filter
Elect fan set up
Crane elect ign and coil
Amongsth this he also gave me:
A 2nd windscreen
Full set of a arms, spindles, hubs etc.. used.
A new unmounted top
A set of autometer gauges
A spare 1500 trans (Now resealed and installed)
Monza exhaust (Now on Rick B's Car)
OEM style new muffler/resonator setup
Not ball for $600. A few hundred out of my own pocket and it's become quite a resonable dailey Driver. Not looking bad either. I'd keep it but the Body was an inappropriatally repaired PA Car and is being held together with varios pieces of metal rivets and bondo, While my 76 Tub is nearly rust free.
jlaird
Sounds like it should be a solid engine.
maxwedge5281 Front Shroud Differences: 3000 vs. BJ8 Austin Healey 5
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
Jake BN1 Front Shroud Badge - What is original? Austin Healey 4
Marvin Gruber Front shroud piece needed Austin Healey 16
Healey Nut Front shroud badge Austin Healey 66
BoyRacer front shroud templates for 3000 Austin Healey 4
B Fitting grille surround to front shroud - BJ7 - any advice? Austin Healey 21
B Painting underside of front and rear shroud - Original prep and color? Austin Healey 3
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
E relief map of lower front shroud 61 bt7 tricarb Austin Healey 0
germanmichel BT7 shroud connecting at front frame rail plates Austin Healey 6
T Front Shroud Qustions Austin Healey 8
T 1955 BN1 front shroud Austin Healey 3
T Austin Healey front shroud FORUM Navigation Questions 1
H front shroud-pls clarrify holes for me thanks Austin Healey 9
O front shroud work in Northwest Austin Healey 5
H Wheight front shroud Austin Healey 3000+transport Austin Healey 18
richberman Pictures of BN4 front shroud/chassis joint Austin Healey 5
J Healey BJ8 Front Shroud Phase1 / Phase2 ? Austin Healey 7
Y Restoring a 58 100 six front shroud Austin Healey 1
T Front Shroud Adhesive Austin Healey 10
T 100 Front Shroud Attachment Austin Healey 0
J front shroud to fender welt Austin Healey 4
C Front apron to shroud clearance Austin Healey 21
Bob Claffie Front shroud asm Austin Healey 5
timbn2 Front Shroud for 100 Austin Healey 2
AUSMHLY Rain channel screws, front shroud Austin Healey 1
AUSMHLY Front Shroud replacement Austin Healey 28
S Front shroud and fenders Austin Healey 12
N BJ8 front Shroud Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
