Front End Shake
The shake begins around 55-60 mph, and is quite noticeable up through steering column. It has wire wheels and new Firestone tyres. What are the first and second steps to take in resolving it? Front end alignment? Have wires trued? Thanks for the tips. It is exciting to have it on the road!
craigshealey3000
The shake begins around 55-60 mph, it is quite noticeable up through steering column. It has wire wheels and new Firestone tyres. What is the first, second steps to take in resolving it? Front end alignment? have wires trued? thanks for the tips. It is exciting to have it on the road!
I found this about tire shaving, anyone had this done? I'm in Myrtle Beach SC and looking for a good British car repair shop:
Mickey Richaud
Hi, Craig -
Hendrix Wire Wheel in Greensboro NC - they're a well-respected resource. I had them true my wire wheels (MG T series), and shave and install new tires and tubes. Did a fantastic job, even labeling each assembly as to its location on the car! Check them out: > Hendrix Wire Wheel <
Mickey
BobHaskell
Agree with Mickey's suggestion of sending the wheels to Allen Hendrix. He can true the wheels, balance the wheels/tires and shave the tires. Another thing that causes the Healey scuttle shake is unbalanced brake drums. Something else that Allen can do.
Keoke
Agree with Mickey's suggestion-2-Keoke
Jack T
Craig,
There are many areas to address before getting into tire shaving. That would be the last thing i would do after a thorough appraisal of your front end.
First, place a floor jack beneath the spring pans on each side and check for any play in the wheels. Any wear in the king pins, tie rod ends, or wheel bearings will result in shake at speed. Also check for wear in the splines of the hubs and wheels.
Second, check your alignment. Toe is the only adjustment available on a big Healey, and it's not difficult to do by yourself.
Third, check the balance of the wheels. You say you have new tires, but did the shop that installed them properly balance the wheels? The wire wheels on our cars must be properly mounted to the balancing equipment, and not every tire shop takes the extra time necessary.
Congratulations on getting your car on the road. It is a great driver when all is properly set up.
HealeyRick
It sounds counterintuitive, but your rear brake drums being out of balance is a very likely cause. Send them off to Allen Hendrix. Here's the story: > Hendrix Wire Wheel < Secondly, standard wheel balancing machines won't properly mount the hubs from a Healey for proper balancing. Moss sells a kit to properly mount them, but it's not cheap: > 386-305 Wire Wheel Balancing Tool Set | Moss Motors < Chasing down that shake can be a maddening process. After you've made sure everything is ok with your front suspension, I think I'd send your wheels and tires to Allen to determine if your wheels are true and have them balanced along with tire shaving. Brake drums balanced too. His prices are reasonable, shipping will be high, though. I had that 55 mph shake and now I don't. I did all the above with Allen as well as mounting new Michelin XAS tires on Dayton 72 spoke chrome rims. Then just to make extra sure, I reinforced the transmission tunnel per this article: > Scuttle Shake < I can't say for sure what cured it, since I did everything at the same time. My bet would be the brake drum and wheel balance. Expensive, but it was worth it to get rid of the shake. I've had the car over 100 and it's rock solid.
Hendrix did my rear brake drums years ago. Helped, maybe. Last fall he mounted new tires and shaved them. He balanced the wheels with weights on both sides (I got used to the look). I have no shake all the way up to 90 mph. I've never experienced a smoother ride in 20 years of owning my BJ8.
Check out the price of shipping at Parcel Monkey (name does not exude confidence, I know). They are 50% of UPS and you just pay and print the label online. You take it to the UPS location of your choice. You track just as you would normally. You can get perfect shipping boxes (that hold two each) at any U-Haul store.
Couple things:
- 'Scuttle Shake' isn't unique to Healeys; Mustang convertibles, at least the early ones, had it as well (my dad was a factory rep for Ford when the 'Stang first came out, and he said it was a common complaint from customers; our '65 convertible had it bad). Convertibles don't have the structural rigidity of coupes or sedans, and are usually heavier due to additional bolstering required in the chassis, which may or may not eliminate the shake.
- My BN2 had it, until I got a new set of (5) MCS wheels and Vredestein tires (no shaving required). Now, it's smooth up to 75MPH (I have no reason to go any faster in that car, and the crankshafts are known to fracture above 4,500RPM).
- Shaving tires will likely void the tires' warranties, if that matters to anybody.
Ok, three things.
craigshealey3000
Craig,
Great advice! I'll follow all the steps you have outlined, thank you!
craigshealey3000
Hi, Craig -
Mickey
I spoke to Allen Hendrix, he is a hoot and extremely knowledgeable of course- he even knew the previous owner of my Healey in NC. I like your quote too, I peed on an electric fence more than once until I learned my lesson.
craigshealey3000
I'm going to jack it up first and look for wiggle- King Pins and then may got to Hendrix, thanks!
bob hughes
My BJ7 had the dreaded shake and I was contemplating all sorts of balancing, in the end I had the chance to by some nearly new chrome wheels, I also forked out for new tires and new splined hubs all round. The old splines were really badly worn, The bottom line was that the shake had gone. The actual cause was never really found but the tires were installed onto the rims and balanced on one of those static balancers, absolutely brilliant.
:cheers:
craigshealey3000
:cheers:
Thank you Bob, I took both front wire wheels off, the splines look good. I cleaned and greased everything including the front suspension and tightened all bolts in the front end. Its better but still shakes around 60 mph and rattles my steering wheel hub and turn signal switch.
I may have it balanced and aligned, if that doesn't do it, I may have to spend the money on Chrome wires and new tires.
Oh yeah, now my overdrive also stopped working, checked throttle switch and filled the OD unit with about 1 quart of Castrol 20/50 with Zinc. When i took it for a test drive, it worked! But only for a minute and then it stopped again.
What is my next move?
Thanks!
Legal Bill
It's funny how all these problems create the same scuttle shake. This summer I am determined to eliminate mine. Here is what hasn't worked, yet:
New suspension front and rear.
New hubs and bearings and adjusted to 0 end float.
New brake drums, balanced.
New 72 spoke wheels and Vrederstein tires, balanced on a bubble balancer by Wire Wheel Restoration in Auburn, MA.
Coming up:
Balancing the drive shaft (tomorrow)
High speed balance the wheels at a shop with the correct mounting adaptors for wire wheels. (next week)
Front end alignment at a shop (I already did it with an alignment bar, but I'm sure the shop can get it better).
If these things don't do it, I'm shipping the wheels to Hendrix. I already used a dial indicator to see how far the new wheels are out of round. They are all within spec, but one is right at the limit, .050.
craigshealey3000
Coming up:
Yes, I've spoke to Allen Hendrix and that may be my solution if all else fails, $$$$. Sounds like you are much farther down the road with this issue than I am, but I'm taking it for wheel balancing and alignment next. Good luck.
Legal Bill
The drive shaft was fine. I'll reinstall it in the morning and see if I can find an alignment shop that know what they are doing.
bob hughes
Your overdrive problem may be caused by the solenoid operating erratically, as you have BJ8 it is going to be a bit awkward getting access on the BJ7 I can easily remove the gearbox tunnel. With the ignition on and the O/D switch on, can you hear clicking when you move the gear lever across the gate, that would be the solenoid coming into action. That is straight for the jugular, it could be that the gear switch has worn if it is intermittent, there are a number of checks you can carry out on the various switches that are in the circuit, have you got the workshop manual ?
:cheers:
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
Dave Russell Front End Shake at Higher Speeds Austin Healey 5
C Front End Shake at Higher Speeds Austin Healey 5
C BN6 Front end shake at high speeds Austin Healey 7
G MGB '71 MGB Front End Rebuild MG 2
X Front End Alignment Austin Healey 14
B Bent frame rails near BE front end Spridgets 2
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
AUSMHLY BJ8 Front End Squeak Austin Healey 25
AUSMHLY 64 front end too high Austin Healey 14
thibault BJ8 plus 55mph Front end shaking Austin Healey 100
vette Effects of Lowering the Front End Austin Healey 21
G Front end Alignment - Total Toe vs. Individual Toe Austin Healey 3
R Front wheel bearing - end float Austin Healey 40
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
K TR2/3/3A Front end woes... Triumph 18
S Wedge tr8 front end Triumph 0
B TR2/3/3A Front end alignment Triumph 23
Jim_Gruber Bugsy IV Front End Rebuild Spridgets 5
mcmillal TR4/4A Front End Vibration Triumph 9
K TR2/3/3A Front end Question.... Triumph 4
M front end alignment Austin Healey 12
T TR4/4A Front end alignment specs for lowered car Triumph 2
Joe Reed MGB Rattle under front end? MG 8
J MGB Project car done; front end clunk noise while braking MG 4
S TR2/3/3A Front end alignment and tire wear Triumph 9
aeronca65t Minor front end work Spridgets 12
RAC68 Calculating Front Hub End-Play Austin Healey 32
aeronca65t front end maintenance Spridgets 5
bugedd Front end rebuilt help Spridgets 6
BlueMax Front End Completed Spridgets 23
bugedd About to rebuild front end...any tips? Spridgets 5
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
K TR2/3/3A Front end reassembly: trunnion spindles and wishbone bushes??? Triumph 10
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
D XJ6 series III front end rattle Jaguar 5
Tr3aguy Front end rebuild questions>? Triumph 6
S Finally got my front end back together Triumph 5
O TR2/3/3A TR3 front End Alignment Triumph 8
RickB Box Spridget fiberglass front end - front mounting Spridgets 5
K TR6 TR6 front end Triumph 2
Burrell22 TR4/4A Tr4 front end help. Triumph 10
B Bugeye front end Spridgets 0
H Should I drop the front end down a little? Austin Healey 25
M Advice on doing a front end rebuild via kit? Spridgets 4
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
S TR2/3/3A tr3 front end alignment Triumph 9
