Front End Shake at Higher Speeds
Dave Russell
Yoda - R.I.P
Hi Chuck,
I think you may have a couple of problems. Try the easy things first.
The steering is way too loose. I'm not sure that it would cause shake though. There are adjustments on the steering box that will usually remove the play. The one on top removes worm to peg play. Tighten it down but not so tight that the steering binds. The steering shaft, part that the steering wheel is attached to, is adjusted by removing shims under the end cover. This shaft often has too much end play. I really suggest that you get a good shop manual. There are a bunch of other places that could be worn. Check all of the steering linkage joints. You may have a combination of steering problems.
The shake can be caused by tire, wheel, or brake drum imbalance. If you are sure about the wheels & tires, having the brake drums balanced sometimes solves a persistent problem. Some of them were machined way off center.
Good luck,
Re: Front End Shake at Higher Speeds
Thanks Dave,
Where do you get drums balanced? Same place as turning? I will check with a good cars part shop (Make, Model & Year) here in Phoenix vs Checker, etc. Maybe NAPA is OK?
Chuck
Chuck,
I have gotten my brake drums turned and balanced at a Napa machine shop. It only cost $10 per drum. Well worth the money.
Robert
Thanks Dave,
I adjusted the steering as you and Keoke advised. It is much better now but maybe a little tight which I will adjust next weekend . I took tires/wheels back for a balancing check and the drums in to be turned, The drums were very good with little to take off. One of the wheels needed balancing (they said it was enough off to cause vibration). I guess I should have checked that first. I took my Healey for a test today on the freeway and it didn't shudder. I estimate I was going about 60+ but since my speedometer isn't correct (next post) I can only guess. Thanks again for all your advice.
Cheers,
Chuck
craigshealey3000 Front End Shake Austin Healey 31
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
C Front End Shake at Higher Speeds Austin Healey 5
C BN6 Front end shake at high speeds Austin Healey 7
G MGB '71 MGB Front End Rebuild MG 2
X Front End Alignment Austin Healey 14
B Bent frame rails near BE front end Spridgets 2
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
AUSMHLY BJ8 Front End Squeak Austin Healey 25
AUSMHLY 64 front end too high Austin Healey 14
thibault BJ8 plus 55mph Front end shaking Austin Healey 100
vette Effects of Lowering the Front End Austin Healey 21
G Front end Alignment - Total Toe vs. Individual Toe Austin Healey 3
R Front wheel bearing - end float Austin Healey 40
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
K TR2/3/3A Front end woes... Triumph 18
S Wedge tr8 front end Triumph 0
B TR2/3/3A Front end alignment Triumph 23
Jim_Gruber Bugsy IV Front End Rebuild Spridgets 5
mcmillal TR4/4A Front End Vibration Triumph 9
K TR2/3/3A Front end Question.... Triumph 4
M front end alignment Austin Healey 12
T TR4/4A Front end alignment specs for lowered car Triumph 2
Joe Reed MGB Rattle under front end? MG 8
J MGB Project car done; front end clunk noise while braking MG 4
S TR2/3/3A Front end alignment and tire wear Triumph 9
aeronca65t Minor front end work Spridgets 12
RAC68 Calculating Front Hub End-Play Austin Healey 32
aeronca65t front end maintenance Spridgets 5
bugedd Front end rebuilt help Spridgets 6
BlueMax Front End Completed Spridgets 23
bugedd About to rebuild front end...any tips? Spridgets 5
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
K TR2/3/3A Front end reassembly: trunnion spindles and wishbone bushes??? Triumph 10
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
D XJ6 series III front end rattle Jaguar 5
Tr3aguy Front end rebuild questions>? Triumph 6
S Finally got my front end back together Triumph 5
O TR2/3/3A TR3 front End Alignment Triumph 8
RickB Box Spridget fiberglass front end - front mounting Spridgets 5
K TR6 TR6 front end Triumph 2
Burrell22 TR4/4A Tr4 front end help. Triumph 10
B Bugeye front end Spridgets 0
H Should I drop the front end down a little? Austin Healey 25
M Advice on doing a front end rebuild via kit? Spridgets 4
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
S TR2/3/3A tr3 front end alignment Triumph 9
