MGB Front Cross member pads
Boggsy64
Well as I progressed to put the front suspension back together I thought I would see if the front cross member was tight against the frame. Sure enough a little jack pressure and it moved. So I guess the pads need changed. Looking at the bolts and reading other internet posts (you know how that goes) it sounds fairly simple to replace the pads. One question: the bolts appear to be studs with threads on both ends. Mine have nyloc type nuts on top and bottom. If you try to loosen the nuts will the whole stud turn? I am a one man shop right now and don't have a way (at least an easy way) to hold the nuts in the engine compartment and crawl under to get at the lower nuts at the same time. OR can you simple loosen the lower nuts and not secure the top nuts? The diagram shows the stud having a middle section that looks like a shoulder of some kind. I did not know if the top nuts pulled the stud into place and then the lower nuts could be applied and removed independent of the upper nuts. I would like to know what to expect before I get started.
I just talked to John Twist at University Motors about this. He is a great guy and helpful! He confirmed what I thought the shoulder on the cross member bolts is pulled up into the frame and only the bottom nuts need be removed to replace the pads. The shoulder effectively turns the long bolt into a "stud" on the bottom. There is a chance the upper nut will spin but not usually.
Let us know how it goes. I've not had to dig into that part of my suspension system yet.
Was sidetracked for a week but just completed the front cross member to body pad replacement. About an hour job in total. Simple 3/4" socket and a jack. Loosened lower bolts only and uppers did not turn. The back two bolts on each side are easy because the nuts are right there for access. The front two are behind the springs but I had removed them already. There is an access hole through the cross member to get at the front bolts and using a "snap on" universal joint adapter that my dad passed to me it was a piece of cake to get the front bolts as well. Using the universal joint socket adapter I could have gotten the nuts off with the whole front assembled.
Only trick is lowering each side the same amount to get the cross member to go back onto the "studs" correctly. I loosened the nuts to just leave enough to support one side while completely removing nuts and replacing the pads on the other side. Then working backwards for reassembly.
The new polyurethane pads are double the thickness of the originals which were nearly gone. Torqued to the proper setting (55 ft lbs) and will allow it to sit overnight and then re-torque just to see if the pads compress some more.
Over all one of the easiest jobs on this old B yet.:smile:
Count your lucky stars - that job can be a bear!
Mickey
J front cross member height from bottom to floor on BJ8 Austin Healey 5
Lin X cross member in front of radiator Austin Healey 4
Guinn Front cross member pads MG 40
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
mjobrien Top cross section at the front header / bow Austin Healey 0
newmexTR3 TR2/3/3A TR3 front cross tube needed Triumph 3
P front cross brace removal Triumph 4
E TR6 TR6 Front fenders Triumph 5
T Wanted MGB Coil Over Front Suspension MG Classifieds 0
S Wanted *** wanted: front right frame section for 1967 BJ8 3000 *** Austin Healey Classifieds 8
71TR6 TR2/3/3A TR3A Front Hood Rain Flap fitting Triumph 7
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
D TR2/3/3A TR3A front suspension rebuild Triumph 47
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
