front cross member height from bottom to floor on BJ8
jpat67bj8
Front end of BJ8 is high. I measure 7 inches from under front cross member to floor. The correct number for the springs were replaced in 2008 from Moss and all front suspension was rebuilt. There is 5 inches from top of 185 tires to fender. Car has been rebuilt from front to back with no modifications to any suspension items. What could be the cause? What should be the height under the front cross member?
Healey Nut
Is the engine/transmission etc all in the car and has it been driven round a bit to settle it on the suspension etc ?
J
jpat67bj8
yes to all. Just now decided to find the problem and correct after a number of other Healey owners committed on the heigth
Healey Nut
My 67 restored in 2012 is 4 3/4” to the floor
My 64 which has less than 30 miles on it since a ground up retoration is 5 1/4” to the floor
take some pics and post them of the front suspension , sounds like something has been put together bass ackwards ?
vette
There might be the possibility that the trunion bushing bolts (at top of swivel pin) and the bottom a-arm bolts were tightened up with the suspension in full droop, then the bushings are keeping the upper and lower A-arms from moving up to normal/average position. Losen the bolts and see if front end drops. If so, tighten bolts according to shop manual instructions.
There might be the possibility that the trunion bushing bolts (at top of swivel pin) and the bottom a-arm bolts were tightened up with the suspension in full droop, then the bushings are keeping the upper and lower A-arms from moving up to normal/average position. Loosen the bolts and see if front end drops. If so, tighten bolts according to shop manual instructions.
Good call! It would be nice if that solved the problem.
Boggsy64 MGB Front Cross member pads MG 4
Lin X cross member in front of radiator Austin Healey 4
Guinn Front cross member pads MG 40
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
mjobrien Top cross section at the front header / bow Austin Healey 0
newmexTR3 TR2/3/3A TR3 front cross tube needed Triumph 3
P front cross brace removal Triumph 4
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
G MGB '71 MGB Front End Rebuild MG 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
