Fine tuning the 1275, with unknowns . . .
V
vagt6
I have a bit of a challenge on my recently purchased '74 MKIII Midget and I'd appreciate input from you 1275 gurus out there on how to fine tune the engine.
The engine appears to be in very good shape (it's sure is clean!), rebuilt approximately 8K miles/5 years ago. It has roller rockers; upgraded cam; Pertronix; HS2s rebuilt; Datsun starter; head ported/polished; oil cooler; Haynes electric fan, and more. It does not smoke, leak, etc., and runs well.
I have documentation for all of this work, but not the cam, only that it's not stock (I've asked the P.O., he couldn't help as he's not the "mechanical type"). As such, I'm not sure where to set the valve lash. Thankfully, it's in good tune now so I'll probably see what the valve clearances are now and stick with those settings for the time being.
I'd like to assume that if it's a street cam (it idles at about 1050 RPM - below that it's choppy) the lash may be something like .014 on intake and maybe .016ish exhaust (this is inferred from APT and Piper websites for their popular street cams), but who knows? I'm pulling the valve cover this weekend to do a bit of exploring in there.
Reading the plugs, they look pretty good. The old plugs were moderately carbon fouled so I backed off the jet adjusting nuts a couple of flats and the newly installed plugs with about 100 miles look much better. The plug ground straps look a little burned (no color deliniation line on the strap) and the porcelain is snow white - no metal spots).
New car (to me), I don't want to assume anything. What do you think? How would you proceed? The valve lash must be adjusted someday, what to do?
Thanks for all the help.
Mark, this cars are not that precise, so whether you did it a .014-.016" would not be any big deal, there that much room for human error,in how a couple different people feel the feeler gauges, so don't sweat, .014,.015 or .016 they will all work just fine, just pick one of those numbers and go with, and yes you are correct to assume, almost all A-series cams lash are somewhere between .014-.016". I will give youthis piece of advice when adjusting valves on roller rocker arms, muvoe the feeler gauge from side to saide, not inward and outward like you would with regular rocker arm, in other word from side to side on the roller tip, into the roller tip.
I thought A-series tappet clearances (with a stock cam and stock rocker arms) was typically 0.012"
Most documentation I've seen says that you multiply the standard gap by the altered ratio of the rocker arms if the arms are not stock. For example, if the standard arms have a ratio of 1.22:1 and the roller rockers you have are 1.5:1, the new gap would be 0.012" x (1.5 / 1.22) = 0.0148 or realistically 0.015".
Regardless, I'll bet most of us have wider gaps than that. What's the old saying... better to hear the valves than burn them?
None of this stuff is stock, though, Doug. Both cam and roller rockers are aftermarket and I don't know the specs (and I'm not going to tear the engine down to find out!). Probably the valves, too.
Anyway, with ideas from Hap and others I'll muddle through.
Thanks, guys!
Well, you can always put a dial indicator over a pushrod to measure the lift the cam is giving you and you can carefully use a scale or calipers to measure the relative lengths of the rocker arms to determine their ratio. That information won't fully enlighten you but you'll have a better idea how those two parts compare to stock.
Not that this will help any, but the recommended lash on the cam I've got in my 1098 says .018 HOT. It is an odd one from Oregon Cam Regrinders that has 107 degrees seperation. Not much on the top end, but tons of low end grunt.
WALTER fine tuning body work Spridgets 5
S TR2/3/3A ÂĽ fine square nuts Triumph 7
T why would an intake manifold stud have both coarse and fine threads? Spridgets 8
GTP1960 A fine lookin truck. Other Cars 3
David Townsend General TR Garage Sale! Limited Edition Fine Art Prints Triumph 2
David Townsend Annual Holiday Sale On Limited Edition Fine Art Prints! British Motor Corp 1
David Townsend Annual Holiday Sale On Limited Edition Fine Art Prints! Sunbeam (Rootes) 0
David Townsend Annual Holiday Sale On Limited Edition Fine Art Prints! Jaguar 2
David Townsend General TR Annual Holiday Sale On Limited Edition Fine Art Prints! Triumph 2
David Townsend General MG Annual Holiday Sale OnLimited Edition Fine Art Prints! MG 2
David Townsend Annual Holiday Sale On All Limited Edition Fine Art Prints! Austin Healey 1
David Townsend GT6 GT6 and Spitfire Fine Art Prints Triumph 0
T MGB My '80 B used to shift fine MG 2
David Townsend General TR SALE! All Triumph Limited Edition Fine Art Prints! Triumph 0
David Townsend MK I, MK II, Cooper S Limited Edition Fine Art Prints British Motor Corp 0
David Townsend Post-War Other Swallow Doretti Limited Edition Fine Art Prints Triumph 0
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
David Townsend Spitfire Spitfire MKIII Limited Edition Fine Art Prints Triumph 0
David Townsend XK120 FHC Fine Art Prints Jaguar 4
David Townsend MGB 1975-80 MGB Roadster Fine Art Prints MG 0
David Townsend E-Type Limited Edition Fine Art Prints Jaguar 3
David Townsend BN7/BT7 Limited Edition Fine Art Prints Austin Healey 6
David Townsend BJ7 Limited Edition Fine Art Prints Austin Healey 3
J Starter works fine but car catches after you let off on the starter Austin Healey 14
H Spitfire Triumph starts just fine but Ignition is 'Off' and key is in my wife's purse. Triumph 6
jaegzie Disc brake upgrade was fine now major alignment issue. Spridgets 6
CJD TR2/3/3A Coarse Vrs. Fine Knock Offs Triumph 5
bighealeysource Best way to remove very fine scratches in chrome windshield frame Restoration & Tools 2
bighealeysource Best way to remove very fine scratches in chrome windshield frame Austin Healey 1
Boggsy64 MGB King Pins appear fine am I missing something? MG 3
T Doug Reid AKA Mr. Fine Spanner Austin Healey 7
Schroeders Any of you fine folks have 1275 shift lever FS? MG 2
S Started fine after 3 years!! Spridgets 8
zimmy runs fine but wont start Spridgets 15
YankeeTR Injection is fine but I'd rather be.... Triumph 2
G A fine time to have a VOR..... Triumph 8
boxofparts Another fine MF designed product Triumph 2
W OK Fine ... try this one ! MG 10
jaybird There's a fine line between hobby and illness MG 17
K ran fine, now sputtering/backfiring at speed MG 8
G READ THE FINE PRINT!!!!! Restoration & Tools 3
G Hard starting, but then runs fine MG 6
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
F TR6 tuning webbers Triumph 3
jehuie Tuning up a 1275 Spridgets 17
HealeyPassion EFI AH testing/tuning remotely Austin Healey 2
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
D 62 tri-carb tuning question Austin Healey 8
M Carb Tuning Austin Healey 40
