runs fine but wont start
zimmy
my car starts from a push switch since the ignition switch is broken ......
first i turn on the key...
tick tick tick goes the
fuel pump....
i press the button, it starts.
well, now when i press the button,
all i get is a tick from the relay.
so, i changed the solinoid.....
didnt work..
so, i changed the relay....
didnt work...
i tried jumping the switch....
just the tick....
it DOES start if i push it or
if i jump to the starter...
the switch is on new wire..
battery to relay...
any ideas.......zimmy
Zimmy:
Be sure to check your battery terminals and cables for a possible loose connection and or corrosion.
I have seen cables corrode underneath the rubber insulation to the point of rendering the cable incapable of delivering a full load of amperage to the solonoid or starter. Check the ground cable for corrosion as well.
The next thing is to check your battery make sure it is fully charged.
Good battery, good cables, new solonoid, new relay, the only thing left is the starter itself and you say that it will spin with a jump so it must be ok.
How about just a plain old bad battery connection?
Is the solenoid grounded? It has to be for it to work.
Or you might have a bad solenoid. If it's new and came in a green Lucas (India) box, suspect it being bad.
A generic Ford solenoid will work too.
new battery and cables,,,,,,
with motor running at 1500 rpm
i get almost 14 volts at ALL the
electrical locations...coil, solinoid,
alt, and the battery.....z
That sounds about right for a good charging system. Sounds like the points in you solenoid are not good or are not making or maybe you have a dead spot on the starter commutator, the spridget starters usually have a square deal that sticks out so you can turn it a little if needed.
Always park at the top of a hill.!?!? Back thirty yrs ago I had a buddy who did it for a long time. If you don't have any hills, You Are In Trouble I was laughing about this post and told my wife about it and who it was, she told me its getting closer to thirtyfive yrs ago than thirty, time does fly.
Aye, for sure.
If you have the old-style solenoid, it is a fairly simple task to take it apart and fix it (at least once it is apart you can diagnose why it failed - it will either be fixable or need replacing anyway!!)
its under warranty, already got a new one......
im thinking it might not be grounded good...
ill get back with u later today.......z
i forgot the solinoid has to be bolted down to be grounded...works fine now....i was late for work
when i was tryin new parts at Oreillys...ooops....
im pretty sure the old solinoid was bad though.......z
G Hard starting, but then runs fine MG 6
Bayless Onslo the Sprite runs Spridgets 4
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
B TR2/3/3A It runs, again Triumph 3
D For Sale 1955 DAIMLER CONQUEST RUNS NEEDS RESTORATION. Other British Classifieds 1
M Midget runs inconsistently Spridgets 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
F TR6 1975 TR6 runs lean Triumph 11
FlyingCat Spitfire Runs, but not well Triumph 26
B Fuel pipe runs BJ8 Austin Healey 2
D TR2/3/3A Alternator dial runs high Triumph 5
D Its Runs! Spridgets 6
D Lilly test runs Austin Healey 4
2billydavies TR2/3/3A runs excellent but starts hard after use Triumph 8
C runs better without air cleaners?? Austin Healey 19
KVH General Tech TR4A Runs Terrific Triumph 2
Tinkerman TR2/3/3A It runs! Triumph 8
B T-Series 51 td runs rich MG 17
Gundy Runs a bit...then quits Spridgets 18
HealeyRick Runs a Bit - Then Quits Spridgets 23
K Hard Start, runs poorly when cold Spridgets 10
gbtr6 TR6 Help! Starter runs with ignition in on position Triumph 18
drooartz MGB-GT It runs! MG 6
C Ship deliberately runs aground carrying Jaguars and Land Rovers, but why? Jaguar 0
M TR6 TR-250 CC engine runs great, then nada, wait > 2 days, then runs great again, repeat Triumph 7
B Everything runs better with this mod - all models!!! Spridgets 7
DanLewis Runs on 3 cylinders at idle, but all 4 at higher rpms??? Spridgets 25
D TR6 Blower runs off and on Triumph 4
N Runs Rough Under Load Spridgets 15
Sarastro T-Series It runs! MG 8
R engine runs cool Austin Healey 16
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
martin_burtt TR6 TR6 - runs but no power under load? Triumph 11
af3683 TR2/3/3A Set Static Timing on TR3B - Car Runs Poorly Triumph 27
T She runs! She won't stop running! Triumph 2
C '72 Midget Runs On 2 Cylinders at Highway Speeds Spridgets 73
N After 30 years, it runs! Austin Healey 7
S TR2/3/3A TR-3 hard to start, but runs well once started Triumph 5
G Well, it runs and drives Triumph 5
V Fuel pump runs continuously! Spridgets 18
livinginthepast After a long winter's nap - BE runs around town... Spridgets 7
Wizardd MGB '77 MGB runs for a bit, then shuts down MG 28
bighealeysource BN6 runs rough on restart after running great Austin Healey 7
C My car runs unevenly...... Triumph 4
DART IT RUNS!!!!!!!! Other British Cars 3
jlaird New. She runs but. Spridgets 7
Westfield_XI MegaJolted 1380 starts and runs Spridgets 6
livinginthepast Runs good...starts missing...and then.. Spridgets 10
mikecyc72usa Finally, it runs! Triumph 8
